Question about Refrigerators
Maytag refrigerator model # mbr1952kes ... i want to reverse the way the door opens... i know you have to take out the plastic inside the door and flip it around but i want to know how to change the side that the handle is on.... please / thanks Amanda D. Canada
aborcass
  • 2651 Answers
SOURCE: Burning plastic smell INSIDE refrigerator
look for a door/light switch, and depress it do the lights go out?? bad switch will keep the lights on and melt plastic lens covers.. could also be nothing and you happened to open open the door right as a defrost cycle was completing( there is a heating elemnt in your freezer) watch your dairy, ice cream nad milk are real good indicators of refrigeration issues. as far as runnig all the time no real" time limit" as to how long it should be running.
Posted on Mar 04, 2008
dragonsthatk
  • 547 Answers
SOURCE: Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Posted on Feb 11, 2009
  • 2692 Answers
SOURCE: want to reverse door handles
On most you take the top hindge off. Lift the door off the bottom one then remove the bottom hindge.
Posted on May 09, 2009
SOURCE: Doors hard to open
My husband, an engineer, fixed this problem after a service visit did nothing to fix the hard to open door problem. He duct taped a small section of a straw (about 4 inches) to the inside top of the door frame so that one end of the straw was inside of the fridge and the other end was on the outside. It doesn't even show. Voila! Pressure released and it's worked great ever since!!
Posted on Jun 10, 2009
SOURCE: Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Posted on Aug 08, 2009
May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
Jul 27, 2008 | Maytag Refrigerators
Reverse door.
Some cannot be reversed....
May 28, 2015 | Amana Refrigerators
Door slams open Maytag Fridge MZD2766
Human error may have resulted in the hinges being installed incorrectly. To confirm your suspicion, check a similar Maytag on display in a store.
May 26, 2017 | Maytag MFD2561HE Bottom Freezer French...
Side by side bottom freezer,handle came off freezer door,how does it go back on?
Does it had a screw? Different models or different manudfacturer have different ways of doing that, basically the two common way are:
1. Slide type ( just slide it from top to bottom)
2. Screw type ( you'll need to open the inside of the door itself) take out the plastic trya and screw aroun it together with the magnets, thats how you can get access to it.
I suggest call a technician
Nov 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag french door bottom freezer (does NOT have water/ice dispenser on door). There is moisture on the door seal - the movable piece - which ends up dripping on the floor every time you open the door. ...
You have a seal problem around the door or the heat strip inside the frame to prevent this is not working. Or both. So you are sure the model is the MFD2560HES. Let me know if you want me to help you solve this, Sea Breeze
Jun 11, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Mar 03, 2008 | Refrigerators
Freezer door won't open
There is no lock. More than likely the Door is off track and needs to be reset or ice has set up in the track ceaseing the rails up. In any case this isn't easy you need to get your bottommount freezer door pulled open you may have to use some force and be very careful not to brake it there is alot of plastic. Once you get the door completely out of freezer unclip the rails from the plastice rails and reset the two gears (evenly) to make door shut right. Push metal rails all the way back to you hear a click. Then reverse steps to install freezer door.
Dec 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
