Question about HP OfficeJet 6110 All-In-One InkJet Printer
Getting a "fax send failed" error message when trying to send a fax.
  • 16 Answers
SOURCE: error message
Try to send the fax at a different time when telephone line conditions have improved.
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Posted on Jan 05, 2008
SOURCE: Hi, Remote Fax Error being displayed
you talked about pressing options 15 times. where this key is located please?
Posted on Mar 13, 2008
Ajkill
  • 2035 Answers
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Posted on Mar 15, 2008
  • 138 Answers
SOURCE: fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Posted on Aug 26, 2008
laxmankumar
  • 191 Answers
SOURCE: Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
Posted on May 23, 2009
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
Error message says fax failure
Check your phone line to make sure you are connected. If this is a newly installed fax machine, make sure the fax application is downloaded.
Sep 28, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Problem faxing-error message
Error 388:
Definition
Solution
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Set the DRPD in the settings to 9600 and then try send a fax ...
Jan 29, 2009 | Dell 924 All-in-One InkJet Printer
Fax
Solutions:
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
Printer error
error message 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
*Try sending at a lower transmission speed.
Dec 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
247 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
