Question about Clarion APX1301 420W MONO POWER AMPLIFIER Model APX1301 Part No. APX1301
My amp is stuck in "Protect" Mode, how do I get it out?
    New Friend:
  • 3 Answers
Check the resistor R43 and the capacitor beside R43 if not , the input RCA..can you please give me the color code of R43, thank you
Posted on Aug 27, 2013
4 Suggested Answers
SOURCE: cant get protect mode off on amp
you burned up a couple of dioeds if if wnt go back to a regular mode
Posted on Apr 02, 2009
  • 13 Answers
SOURCE: amp displays the letters curr
? The amplifier has been shutdown due to excessive current. ? Find and eliminate the cause of the excessive current, then turn the power off then back on from the remote control unit. ALPINE ELECTRONICS OF AMERICA, INC. 19145 Gramercy Place, Torrance, California 90501, U.S.A. Phone 1-800-ALPINE-1 (1-800-257-4631)
Posted on Jun 10, 2009
bass monster
SOURCE: the amp is in protect mode how do i get it out of
ok one of the most obvious reasons could be that the ground is not properly grounded but there are many reasons like something is hooked up wrong check all your connections before you turn to the internals or it could even be the fuses..
Posted on Sep 07, 2009
It is stuck in protect and wont come out
bro...i had problem like that before and i found out that the load(speakers) was high thats why the fuse always blow...or...check the wire to the speakers if they are sorted or touched.gud luck
Oct 26, 2012 | Rockford Fosgate T1000-1bd - 1000W...
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 19, 2011 | Harman Kardon Audio Players & Recorders
I wanna supplied my Amplifier Lanzar MNX 250 with an 12V - 30 Ohm battery, but the led of my amplifier is red and my speaker doesn't play music. How can I fix the "protect mode" in which the...
  1. The battery is 12 volts and Ohms has nothing to do with your amp installation.
  2. Was the amp running and got hot? Many times an amp will go into "thermal mode" when used for an extended amount of time and need to cool down but I assume if you are trying to hook it up you were not using it.
  3. You need to check the ground wire real well. A loose ground will cause protect mode.
  4. Recheck the speaker wires and their connections. If they cross this to can cause protection mode.
  5. This is a 4 Ohm amp, are your speakers 4 ohm or lower> If not then you may be running to low of a load to your amplifier.
  6. I always remove everything from the amp first and power it on and then add wires and see where which connection throws the amp into power mode.
  7. Check the fuse as well but if the LED is on chances are your fuse is good.
  8. If you check all of the items I listed and the amp still goes into protect mode then your amp is bad.
Regards, Tony
May 05, 2011 | Lanzar MNX250 2Channel Car Amp
I have a fisher intergrated amp ca-9025 that is stuck on stand by. Ive tried unplugging it for 29 mins, and turning it off and on and holding down the tuner button for 10 secs. I also tried holding down...
There is an internal problem that is causing the amp to go into protect mode. Your amp uses a large IC as the final amp stage. This could be defective. See the link below for an explanation of protect mode. Feel free to post any additional questions that you may have.
Thanks,
Dan
LInk: http://www.fixya.com/support/r5390728-protector_means
May 01, 2011 | Audio Players & Recorders
Amp stuck in protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections. Good Luck.A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 22, 2009 | Power Acoustik Car Audio & Video
My amp is stuck on protect mode. what do i do? its a lightning audio. the green light is not on the only light is the red protect light
the amp will need to be repair because it has a fault that it is seeing internally. so not much you can do other than buy a new amp or get that one repair. probably cost effective to buy new. hope this help. good luck
Nov 03, 2009 | Lightning Audio B2.300.2 Car Audio...
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Clarion APX1301 420W MONO POWER AMPLIFIER Model APX1301 Part No. APX1301 Logo
107 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
