Question about LG Flatron L1510M 15" LCD Monitor
Hi I have an LG1510M monitor, I turn it on and after a few seconds it goes dark... yes it doesn´t turn off only the lamps go off, can somebody give some support, I already dismount the cards but there is no evident damage on...
  • 1 more comment
  • atovar_2000 Aug 06, 2010
    Thank a lot, I will start to do this tomorrow morning and I will keep you informed.
    By the way: I already cheked all the capacitors and they look very well and there are no signs of burns or heating on the power card.
    Hi, again, please were can I purchase the replacement for the lamps? I tryed on internet but unsucessfully, please if you know let me know.
    Thanks a lot in advance!!!
  • atovar_2000 Aug 07, 2010
    Hello! Good morning: I started with some tests due that there is no visible damage to the components, I disconnect the control board from the power-inverter board and energize it, obviously there is no response...blank,but after that I reconnected the control board and tested again, surprise!!! now the panel works and I am testing it until I can be sure that it is fixed, I remembered that comment about the "Driver IC cuts the curent" probably there was something that causes that the panel comes to be "protected" and needs to be "reset", it working now but I have it under test..... Thanks again and I will keep you informed, have a nice day!
  • 225 Answers
Check the capacitors on the power/inverter PCB. They have to be flat on top, not swollen. If in doubt replace them.
One or more of the light bulbs are blown. The circuit checks the current and when it's missing, the driver IC cuts the power to prevent more damage.
Connect the bulbs one by one and turn on to see when the screen will not illuminate for that few seconds to determine the broken one. Replacing a bulb is hard because the opening of the LCD and leads to image defects because the dust in the air.
It's a good idea to connect the feedback from a working bulb to the broken one and thus cheat the electronic.
Posted on Aug 05, 2010
Testimonial: "Very helpful information, totomitak seems to me that really know what we are talking about (technically)...Thanks again Now I have to get new lamps!"
  • 8 more comments
  • Dimitar Todorov Aug 06, 2010
    Extract the lamp and measure its lenght. Then just look for "backlight CCFL bulb LCD TFT XXXmm" on ebay. (replace XXX with the lenght in milimeters)
    Thanks a lot, all the lamps seems to be weared (the end look gray-black instead of white), they turn on (all 4) but I will try changing them for new ones, if the failure persist... I will be online again! thanks
  • Dimitar Todorov Aug 07, 2010
    If weared the lamps will glow pink. Before changing them try to measure the transistors of the inverter. Some of them may be faulty. If there are ceramic capacitors between transistors, replace them.
    Hello! Good morning: I started with some tests due that there is no visible damage to the components, I disconnect the control board from the power-inverter board and energize it, obviously there is no response...blank, but after that I reconnected the control board and tested again, surprise!!! now the panel works and I am testing it until I can be sure that it is fixed, I remembered that comment about the "Driver IC cuts the curent" probably there was something that causes that the panel comes to be "protected" and needs to be "reset", it working now but I have it under test..... Thanks again and I will keep you informed, have a nice day!
    I think at the end the capacitors are faulty. They may look very well and be dry inside in that time. Replace them. Electronics always suffer of not well flatten voltage because the faulty capacitors and perform unpredictable.
    Thanks by the moment the monitor is working well (4:30 hrs under continuous testing), I´m also considering to change them anyway, just to assure the repair.
    Thanks a lot
    By the way: do you know where to get the replacement for an LCD screen of an aquos tv 15"?
  • Dimitar Todorov Aug 08, 2010
    Find the part number at the back of the LCD and look for it on ebay.
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
Monitor problem
Hello Iceage, hi, problem is within your power supply section on the LCD. cannot be specific, but normal repairs usually replacement of large value, and large voltage rating capacitors, especially ones were the cathode is connected to ground. check also for the switching power transistors, usually they are MOSFET. you can either do it yourself, but you need the expertise of electronics, or get professional help.
Apr 15, 2010 | Televison & Video
When watching tv on any mode...after a few seconds screen goes dark and sound goes out...then a few seconds later it all comes back...happends repeatly...any thoughts?
Time to replace Lamp in TV.
Existing lamp getting weak and causing that problem, replace lamp and TV will be fixed.
Buy Sony original lamp for TV safety and lamp replacement procedure is written in user manual.
Thanks.
Jan 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My delle173fpc powers up then goes dark if i swittch it off then back on it will come on for a few seconds then go dark again
You could have a faulty inverter board that supplies high voltage to the CCFL lamp or a faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info. click on this link to their WEB site :-
www.lcdparts.net
Nov 05, 2009 | Dell E173FP 17" LCD Monitor
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
LG Flatron L1510M 15" LCD Monitor Logo
214 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
