Question about Frigidaire Heating & Cooling
I have a frigidaire room air conditioner, model number FAC127PIA that runs well but isn't cooling. I'm curious what the problem might be and if it's something that I can fix myself. Thank you.
SOURCE: No cooling
The compressor overload switch has tripped.
Posted on Aug 14, 2007
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 25 Answers
SOURCE: My CV-13NH portable type room
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
Posted on Aug 18, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
I have a Frigidaire FRA053PU113 portable room air conditioner and I would like to know the location of the temperature sensor. The sensor is item 22 on the parts list, the part number is 5304484406
air conditioner thermostats are located at the front/top of the evaporator coil air inlet where they can monitor the air temperature coming back into the unit from the room
most are a small tube or bulb attached to the fins
Apr 25, 2018 | Frigidaire Heating & Cooling
Split a/c system frigidaire model ffms221wq20 Code E6
Code 'E6' does not show up. Here is the Sears website with codes. It also shows problems and fixes which may help you narrow down your problem.
Model FFMS221WQ20 FRIGIDAIRE SPLIT ROOM AIR CONDITIONER Parts
Sep 18, 2017 | Frigidaire Heating & Cooling
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
My frigidaire Air Conditioner model Lra074at7 is not blowing cool air. Its very hot in the room I have it in. Not sure what to do??
Hello friend, thank you for your inquiry!
I understand that your Frigidaire air conditioner is not blowing cool air. There could be many possibilities to why your appliance is not cooling properly.
· Check to make sure the air vent is not in the open position.
· Make sure there is nothing blocking the airflow of the appliance.
· If your appliance is turned on in a hot room it could take additional time to remove "stored heat" from walls, ceilings, floors, and furniture.
Is your appliance under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this is helpful. -Matt
Aug 19, 2014 | Electrolux FRIGIDAIRE LRA074AT7 6500BTU...
My portable. Air conditioner. Isn't cooling
Could be a number of things, Is the compressor running? If so, are the filters clean? ( Both the outlet and the inlet filters.) One at the front where the air comes out and one at the back where the air goes in.
Sep 07, 2013 | Portable Air Conditioners Portable Cooling...
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
Air Conditioner not blowing cold air . I cleaned the filter. What is wrong?
cleck the coils if they are dirty the system wont cool is the compressor running when the coil is dirty it increases the head pressusre or lower the suction pressure does it freeze up
Sep 13, 2010 | Frigidaire FAX052P7 Compact Room Air...
Units runs but cool air will stop even thou blower continues to run after several minutes cool air starts again
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
May 21, 2010 | LG Electronic Window Air Conditioner
Kenmore room a/c not model 70088
you can test it by running it first at 9 and observe the compressor if it is continously running and cools the room. if it does, then 9 is the coldest and 1 is the hottest setting. but if the compressor would just run a little bit and stop at thermostat setting of 9, then its the reverse. i hope i was able to help.
Jun 27, 2008 | Kenmore 70088 Air Conditioner
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
65 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
