Question about Epson TM H6000IIP Thermal Printer
My Printer Stutters and prints some lines twice. Why is this?
How to clean head HP 7260
HP Photosmart 7150 and 7260 printers
  1. Make sure plain paper is loaded into the In Tray.
  2. To perform the first level cartridge cleaning is a spit and wipe, press and hold the Power button while pressing the Cancel button twice, then release the Power button. The printer will generate a series of noises as it performs the cleaning.
  3. Print a test page from the computer.
  4. Once the cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 5.If the print quality is acceptable, disregard the subsequent steps.
  5. To perform a second level cartridge cleaning, press and hold the Power button while pressing the Cancel button twice. Release the Power button and press the Resume button. The printer will generate a series of noises as it performs the cleaning.
  6. Print a test page from the computer.
  7. Once the cartridge cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 8.If the print quality is acceptable disregard the subsequent steps.
  8. To perform a super clean, press and hold the Power button while pressing the Cancel button twice. Press the Resume button twice then release the Power button. The printer will generate a series of noises.
  9. Print a test page from the computer.
  10. Once the super clean has the completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 11. If the print quality is acceptable disregard the subsequent step.
  11. To perform a pen nozzle test, press and hold the Power button while pressing the Cancel button eight times. Press the Resume button four times then release the Power button. The printer will generate a series of noises then print a page displaying a test pattern. If there are gaps in the printouts the cartridge(s) may need to be replaced.
Jan 17, 2015 | HP PhotoSmart 7260 InkJet Printer
The hp6210 stutters when printing...does one line at time ...takes forever to print a page...then sometimes the next page or next document in que will print regular 'fast print'
Improve the FixYa experience for everyone by voting.
Microsoft has developed a fix to immediately analyze and - hopefully - solve your problem. CLICK HERE for your three mouse click solution.
Apr 27, 2012 | HP OfficeJet 6210 All-In-One InkJet...
LEXMARK z12 IS PRINTING SAME LINE TWICE LIKE
uninstall/reinstall the printer software and drivers
Sep 14, 2009 | Lexmark JetPrinter Z12 color InkJet
My hp printer takes avery long time in printing pages than before
Check that you haven't increased the printing resolution beyond what is sufficient to print your document.
High resolution vs. draft output will cause you to use a lot more ink and will take at least twice as long to print a page because it is likely printing each line at least twice. This is how full color (photo quality) images are printed. If you don't need a photo to be dark, then set your printer to "Standard" or "Draft" settings.
Jul 12, 2009 | HP Officejet 4110 All-In-One InkJet...
The printing is not good, has messy and dull effect.
That's about right for the amount of printing you've done before this problem started to show up.
The solution is to run programs accessed from your printer control menus.
Run first, print head cleaning... perhaps twice.
Then, run print head alignment. In this routine you get several lines printed off and you choose the number correspoinding to the set of lines that line up together the closest. Then, enter that ID number for those aligned lines. Sometimes, its good to do this twice.
You will normally want to do these two routines each and every time you replace print heads.
If you need further guidance, use the comment box below to ask.
Regards,
Worldvet
Jul 04, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Print problem repeating lines
I would try clearing the print que, this is done in the control panel under printers, if that does not work try uninstalling and reinstalling the printer program and drivers.
Hope this helps.
Carl
Feb 07, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Printing twice on same line
Reset to factory defaults by pressing the FF/Load and Tear buttons together while powering on the printer,and try again to print.
Dezzi
Jan 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Epson TM H6000IIP Thermal Printer Logo
124 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
