Question about Emerson EWV601 S-VHS VCR
It was working perfectly until I hit the pause button. When I hit it, it turned off immediately. Now whenever I turn it on, it stays on for a few seconds after the display goes away and then turns off. There is also a VHS tape in it and it won't eject, play, or anything. Any ideas?
  • Emerson Master
  • 5,515 Answers
I believe that the tape must have fowled up and the mechanism has gone haywire and now out of sync. Every video has a mode switch. This tells the electronics what position the mechanism is in. However if the mechanism develops a fault, the mode switch will no longer be able to tell the electronics the true position and thus chaos develops, so the whole thing shuts down. You need to investigate to see if the tape is entangled or damage has occurred.
Posted on Aug 07, 2010
Have a jumbo remote with no code search button also only programs 3 devices tv'vcr&dvd
I had the same problem Johny. Everybody wants to tell you how to program the one with the CODE SEARCH button. Here\'s how to do the one without. Press and hold the item button you wish to program (TV, DVD etc anyone of them can be used for anything) until the LED lights and stays on. Turn the item on manually and point the remote at it and push the power button. When the gadget turns itself off, immediately press the item button again. You can recall the code by pushing the item button until the light turns on again and then press DISP. Now push the number buttons (random is OK). As you hit the correct number of the code, the LED will flash until the four digit code is entered then the LED will go off. You may wish to try for more codes as some function better than others that just simply "work".
Jul 02, 2011 | Innovage Jumbo Remote Control
After tv has been turned on for a few minutes , screen and sound will go off . after i immediately hit the on / off button to turn it off then immediately turn it back on , it will stay on for a few...
Sounds like bad power supply, but polaroid more commonly has problems with there main controller board (the one with all the inputs) Power supply's are fairy cheap and easy to replace. Check www.RNS-Systems.com or E-bay for a replacement. For more detailed info create a new post with your make, Model, and mfr date as polaroid changes part numbers.
Oct 16, 2009 | Polaroid Televison & Video
Ipod shows the help screen with a website
Try thisout and restore th ipod
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Feb 08, 2009 | Apple iPod MA446LL/A MP3 Player
My Philips Go Gear SA3025/37 MP3 player won't charge/turn on
i had the same problem. my reset button was jammed. the problem: the reset button is so deep in the tiny hole its hard to tell if you even really hit it when you put a pen in there and somethign like a sharpened pencil just doesn't go deep enough. i monkeyed around wiht a peice of straw in the reset hole for about 10 seconds then tried to turn it on and it worked. good luck
Jan 24, 2009 | Philips SA3025/37 Flash MP3 Player
Pause function for RCA Lyra RD1072A.
This player does not have the true pause you are looking for. The iPod Nano - 2nd generation - has a true pause - once you hit pause it will stay paused and even go to sleep. When you revive the player it will leave off where you left it.
Dec 08, 2008 | SanDisk Sansa e260 MP3 Player
Zebra 140Xill problem
Whenever you open the printhead, the Pause led will light.
If you hit the Pause button, the printer should go back on-line and resume printing (if you didn't turn it off).
If that doesn't work, try the calibration button (labels will feed out), then the Pause button, then the Feed button.
If you don't want to toss too many labels when you calibrate, the "maximum label length" (or some name like that) can be adjusted through the front panel.
Label_Guy
Sep 14, 2008 | Zebra Printer 140-751-00000
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Mp3 is really screwed :S
Don't play basketball with your MP3 player on board. Your MP3 player is ruined. Buy a new one.
-Potter4
May 31, 2006 | RCA RD1076 MP3 Player
Emerson EWV601 S-VHS VCR Logo
59 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
