FixYa.com
Tags:
Bosch Axxis+ WFR 2460 Front Load Washer
Change from 3 wire to 4 wire dryer cord on bosch...
posted by heynewt on Apr 26, 2008
terminal block has two terminals labeled "L" and one labeled "N" and the previous three cord had the middle wire going to what seems to be a ground.
I have a green wire and a red wire going to each of the "L", a white wire going to the "N" and a black wire going to the ground. It seems weird that no wire from the dryer goes the the "N". I am afraid to plug it in to try. Can you help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 27, 2008
Not Rated (0)
fixum1
Rank:Guru Guru
Rating: 87%, 393 votes
what is the voltage that you are using
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
bosch axxis wfr2460
Hello, my Bosch machine just... Answer This...
WFR 2460 Front loader
Washer overflows from soap... Answer This...
auto load adjustment problem
Our wfr 2460 front load washer... Answer This...
Axxis+ Washer won't turn on??
I replaced the brushes on the... Answer This...
Main Pressure Switch Test or...
My pump started making noise,... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
