Question about Whirlpool GGX9868J Gas Dryer
Gas dryer fires up once and that's it
Dryer will heat up normally, but after the first time, it will not fire up...drum continues to spin and it cools off. I wait a few minutes and try it..same thing.
    Genius:
  • 1,028 Answers
Suspect coils on burner once burner fires and heats up area coil may fail on next firing 2 coils are present.. whirpool sends both in kit
Posted on Apr 27, 2008
GAS DRIER HEATS UPS AND THEN IT GOES OUT. IT WILL GLOW AND THEN IT WILL NOT FIRE UP AFTER THAT.
Posted on Sep 17, 2009
I had this problem and just fixed it. The vent duct in the back of the dryer was completely clogged with lint causing the dryer to overheat and the limiter to shut off the burner. I opened the back of the unit, loosened the duct from the blower and vacuumed it out. Also make sure your vent hose is clear and the exhaust flapper works correctly. While you are at it you should open the front access panel and vacuum everything out. My dryer works like a charm now.
Posted on Aug 21, 2008
Samsung gas dryer heats up and then stops. No lint in dryer trap or hose. What could it be? Heating Element? Reset button? Please help! !
The key to your issue is the gas dryer. you need to know how it works to be able to diagnose it. A gas dryer will only fire up if the thermostat calls for heat and the hi limit thermostat is not tripped and the gas valves open and the igniter fires. Any of these not working will not lt dryer fire up the heat.
lets assume the running thermostat is ok since it fires up initially and they seldom are intermittent. A restricted vent would trip the high limit t-stat quickly and would not fire up again till it cools down and resets, since you have stated that the vent is clear and unrestricted we will again assume the hi limit stat is not the problem
(it still could be if it was faulty and opened up prematurely, but again that is not one of the more frequent issues). The flame detector needs to be satisfied to continue the burn after flame is ignited. The detector is a simple device that is located on the burner plenum and is a bi-metal with a clear window that lets light (flame) through to a bi-metal switch that will interrupt gas supply in case there is no flame. these again are not on the most frequent list of parts going bad.
The most likely cause of this problem is a bad igniter. they glow orange on start up and ignite the gas. even though they glow orange does not mean they are good, most develop cracks in the ceramic material and are very brittle. If a crack is present you seldom can see it and often will look normal in operation, but once heated the second cycle of heat fails to ignite. This can be measured cold by resistance check compared with standard value. I often just change them on a hunch , saves time and part cost is not high. Labor time is often higher checking it's value. Another possibility is an intermittent gas valve and that is harder to diagnose and it is an expensive part. Seldom is the valve intermittent though.
This should give you a good start, good luck
Jun 27, 2014 | Dryers
MAYTAG GAS DRYER NOT HEATING
That sounds to me like you need to replace the coils. They get intermittent with age. Work some then quit take a long time to cool down and work a little more when going bad.
MY MAYTAG DRYER HOME REPAIR VIDS
Jul 20, 2012 | Maytag Dryers
The Hi and Lo gas valve coils do they work in tandem ? Does the Lo stays on all the time ? Ruy ...
Their is 2 coil hosing but one of them has 3 wires and 2 coils inside it. The ignitor does 2 jobs, it lights the fire and acts as a thermocouple through the holding coil. If the flame does not ignite after the sensor detects the heat from it and shuts down then once the ignitor cools down the gas valve is shut down even if power is going to the gas valve. When the temp drops below 105f in the drum the control closes contacts inside allowing power to be supplied to the gas assembly. The ignitor and flame sensor along with the booster holding and secondary coils are all energized at once but the solenoids won't open the valve because the ignitor is hogging the power. The power supplied to it runs through the flame sensor. When the temp inside the sensor reaches a point the bi-metal inside tripped the power to the ignitor and the power gets diverted over to the secondary coil. Thr flame stays on till the temp inside the drum reaches 160f at which time the control thermostat opens circuit to the gas assembly and power is shut down. The drum continues to tumble and when the temp drops once agin below 105 the process is repeated and another blast of heat is shot into the dryer. So what goes wrong? Faulty flame sensor sticking/open, cracked ignitor, old coils that work intermittently or not at all when hot but work again when cooled.themobilian_2866.jpgthemobilian_2865.jpg themobilian_2868.jpgMore here.
Aug 21, 2011 | Whirlpool GGW9878P Gas Dryer
Dryer drum spinning no hot air
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Sep 25, 2010 | Whirlpool GEW9200L Electric Dryer
Gas Dryer only runs burner once after starting, why
Lets see, you have power to the gas assembly so the fuse is good and the ignitor will fire up. But she won't fire off again. The flame sensor is working because the ignitor is coming on and off. That means the control thermostat is working so everything is working. So what's the problem. Simple.933a1bb.jpg The solenoid coils heat up and quit on these machines with a little age. Very difficult to diagnose unless you know the trick.
Cheap parts link, your part sir: AP3094251,
May 14, 2010 | Maytag MDG2706A Gas Dryer
Gas dryer runs but no heat
Those coils are probably getting hot and quitting then after a long time they cool off and work some more then quit again.62a13a2.jpg2720ab1.jpg
Apr 11, 2010 | GE DVLR223 Dryers
Dryer heats intermittently clcles off heat then
Try vacuuming lint and dust out of the burner intake and exhaust ports. Hope this helps!
Dec 05, 2009 | Kenmore 73952 Gas Dryer
My whirlpool lg4634jq2 recently caught fire, then a 3 days later it stopped heating. It turns on and spins, however it will not get hoe. Please help
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 19, 2009 | Whirlpool LGR4634J Gas Dryer
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer intermittently heats.
most likely solenoids after a few firings they tend to open up and not work again until after cool down replace both they usually come in a kit
Sep 14, 2008 | Dryers
Whirlpool GGX9868J Gas Dryer Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
