Question about Toshiba 32CV510U LCD TV
Toshiba 32cv510u. TV turns on. No picture, but has sound. Can hear it cycle through the channels. INPUT stations have the same effect. Is it a bad lamp? The screen appears to still be backlit. About how much for repair costs? This occurred immediately after a thunderstorm.
SOURCE: i have a toshiba 32hl67u lcd tv
I had same thing happen recently on same model. Turned it on one night, light came on in screen, briefly saw info bar at top, then nothing. Cannot get picture, volume or menu. Each time I turn off and turn on the same thing.
Any solution to this appreciated.
Posted on Jan 02, 2009
SOURCE: Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
Posted on Apr 02, 2009
  • 187 Answers
SOURCE: Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
tvtek
  • 1284 Answers
SOURCE: Toshiba 26LV610u TV with no sound on one channel
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
Posted on Nov 05, 2009
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
Channels will not program into tv so that my dvd player and Playstation2 will picture can be seen. I can hear both, but it TV is on wrong station and will not program in
You have a DVD player hooked etc to either channel three or four? Usually this equipment is connected into the Jacks on the rear of the set, that is to say hooked to a video input and not with the tuner, if hooked that way select the input with the remote for the set and see the picture....
Clarify how you are hooked and where
Dec 05, 2012 | Emerson Lc190em2 19" Class Lcd Hdtv
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
Toshiba 32cv510u goes on and off whats wrong ?
It sounds that the T'Con board is faulty. This is a common fault to most of the LCD TV, irrespecitve of brand and model. Just visit this site named 'Electro-help'. so many similar faults and repair to them are described in detail there. Check this link and select the site named above.
Jul 13, 2012 | Toshiba 32CV510U LCD TV
Went to turn the TV on and it will not come on. No sound or picture. There as been no movement or anything done to the TV.
More likely to have power supply failure, the power supply is always running to supply the power to the processor waiting to get th turn on command form the remote control. Look for bad caps in the power supply and check the fuse, Need to verify if you do have the standby 5vdc, you must have this voltage before going any further.
Learn more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Parts:
http://www.shopjimmy.com/catalogsearch/result/index/?q=Toshiba+32CV510U+&limit=100
Jun 14, 2010 | Toshiba 32CV510U LCD TV
Nov 05, 2009 | Toshiba 26LV610U LCD TV
My 32" Toshiba LCD HDTV keeps freezing on the same channel and when I try to change the channel or input selection, it doesn't respond(to the remote or directly on the TV.) The only thing that works is...
These problems are normally caused by the TV station.
1. Call the TV station responsible and ask for the network engineer.
2. Tell him the Day, Time, Channel, Program, basically every little detail about the problem.
3. The station will normally check it and fix it.
Also, contact Toshiba and tell them. Really this is part of the DTV Transition thing. Many stations are reconfiguring and settin up equipment. They sometimes make mistakes. Don't worry much about it unless it continues for more than a week. If you like the station, I would call right away.
May 25, 2009 | Televison & Video
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Feb 24, 2008 | JVC AV-27230 27" TV
Channel Reception
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Jan 21, 2008 | Sony KV-27V42 27" TV
Toshiba 32CV510U LCD TV Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
