Question about Jacuzzi Home
The flaps that should fasten down to hold seat to toilet do not snap into the the provided holes.
    Scholar:
  • 122 Answers
The flaps covering the bolts?? if they are broken, just use a little dab of superglue. make sure the toilet bolts are tight before glueing.
don't go crazy with the glue, just a little dab on each side to hold down the flap
Posted on Aug 20, 2010
How do I get a toilet seat off if it doesn't have the screws under the seat and it also doesn't have the little flap things at the back of the seat with the screws under.
You will have to remove the pan to access seat fitment as sounds like a back to wall lol.
Alternatively cut through bolts holding on seat with a hacksaw blade and go to plumb center and buy a new seat with drop through fasteners
Sep 01, 2015 | Home
After flushing the water run a long time before shutting off
Pull the top off to see the flap come down and seats properly over the hole. The water should fill up if this is correct. If it's off, water will continue to go into the bowl.
Oct 14, 2014 | Jacuzzi Bath Perfecta EZ33 959 White round...
How do I stop a small slow leak into bowl of 1 pc Crane toilet?
The seat where the flap sits could have a nick in it. The flap might not be aligned properly. A temporary fix is to put a small amount of Vaseline on the seat and that should stop the water leak.
Aug 30, 2014 | Home
How do i remove a broken bolt which is embedded in the toilet, the bolt keeps the toilet seat lid fastened to the toilet?
There has to be either a nut and washer under the toilet, or if its reversed a bolt head with a washer under it holding it down. To remove it you can either use a hacksaw blade between the bowl and the bottom of the seat. Or use a dremel tool to slowly cut away the metal rod, etc., from the top. If using hacksaw put down some masking tape on the bowl so you don't scar up the enamel surfacr of the bowl. Work slowly and you will eventulaly cut through it.
Aug 16, 2014 | Crane Plumbing Home
I bought a new Jacuzzi toilet and from day one the screws that hold the seat on will not tighten down enough to keep the seat from slipping out when i go to sit on it. This is very irretating, when you are...
Three wraps of white teflon tape on the threads will often help to keep the assembly tight longer. Since the fastener is made of nylon, there is not really any sort of glue that will work.
Aug 19, 2010 | Jacuzzi Refresh Hygiene Toilet Seat Round...
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Toilet seat connectors mounted on toilet is loose
There should be a way to tighten the bolts without going that far Here's two things:
Look at the lid, with the seat down. The bolts are sometimes covered with a snap-in palstic cap or flap. If so, pry up with a screwdriver. Then use a screwdriver and wrench to tighten.
If the bolts appear to be cast as a part of the hinge assembly, you should be able to reach around the seat to the back side (no pun intended) of the toilet, and tighten with a wrench.
I sometimes use a 'mirror trick' to get a better idea of what's back there. Just use a small mirror and hold it to where you can see the bolt and not on the back.
Hope this gets you going (oops, another unintentional pun).
Best regards, --W/D-- please feel free to rate this solution..thanx!
Aug 01, 2009 | Home
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
How to install Toilet Seat
Use a flat head screwdriver to pry open the plastic pieces that cover the screws. Using the same flat head screw driver, unscrew the large plastic screws holding the old seat in place. There are usually plastic nuts on the underside that you can hold on to while removing the screws. Remove the old seat. Clean the area where the screws were and dry thoroughly. If the new seat has an adhesive pad, remove the covering from the adhesive and put the seat in place. Thread the new screws through the holes and attach with the new nuts. If there aren't new nuts and screws, you can use the old ones, provided they weren't damaged during removal. Snap the caps covering the screws on the new seat in place. Be careful not to over tighten the screws! Since they're plastic, they can be easily damaged by a screwdriver!
Aug 27, 2008 | Hansgrohe E & S Accessories 40522000...
Home Logo
171 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
