Question about Weber Genesis Silver C Grill
The striker button won't light the grill but a match will. It is an older Genesis Silver approximately five years old.
  • 494 Answers
If your piezzo ignitor is still sparking, but not lighting the burners, then you may have one of the following problems. 1) If you have a standard push button piezzo igniter or a rotary style igniter, check for spark. Can you hear or see the spark? It's hard to see the spark in bright daylight. It's easier to view the spark at dusk or dawn. It should spark an "arc" at the burner. If not, adjust it if necessary. 2) The igniter wire may have a short, causing the spark to arc somewhere else along the wire and not at the burner. Replace igniter wire. 3) It's also possible the igniter tip where it sparks has a cracked or broken porcelain portion of the igniter, causing the spark to not arc at the tip where it's supposed to. Replace the igniter piece. 4) Your burner may be clogged or rusted at the point where the ignitor sparks to light it. Clean the burner. 5) If your push button ignitor is not sparking at all, it may be stuck inside from being out in the weather. While pushing it, spray it with WD-40 to unstick it.
Hope this helps. Douglas
Posted on Aug 05, 2010
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
Weber genesis
i would say you have a fulty regulator to save your self sone money
rather than buy name brand you can find them on other sites
i hope this helps you
May 24, 2012 | Weber Genesis Silver B Grill
My back burners wont light but my front two will genesis silver edition
If the Cross Over Tube/Burner is clogged, the ignition flame can't get to the last 2 burners to light them. To check this, light the front 2 burners using the ignitor button and try match lighting the back burners. If they match light, that indicates that the Cross Over Tube is clogged. You will need to remove it to clean it properly. Which can be a chore in itself. Be careful removing it, because if it's rusted, it may break.
Hope this helped you, Kevin and thanks for choosing FixYa.
Aug 07, 2011 | Weber Genesis Silver A Grill
I installed a new 7509 ignitor on my 13 year old weber genesis gas grill and the gas does not ignite when pushing the ignitor button. I installed the ignitor with the box opening on the bottom and checked...
If the spark you see is in the ignitor box and not at the burner(s), then there's a wire loose somewhere or the ignitor is not grounded properly. Also check to see if the ignitor tips in the grill next to burner(s) are covered with grease. If so, clean them with a cotton ball dipped in alcohol. Check each ignitor wire at each ignitor , make sure they are secure,
Feb 20, 2011 | Weber Genesis Silver B Grill
Striker won't light gas
Replace the battery if it has one.
Our cooker had the same problem and hidden on the front bottom left corner was a AA battery.
Flat as a pancake. lol
Jul 04, 2010 | Weber Genesis Silver C Grill
Natural gas version of Genesis Silver won't light even with match; seems that gas is not flowing into grill
Ensure that your hose, regulator, and control assembly are all clear of debris and that the orifice is not plugged.
same thing applies to NG just different way of regulating and different orifice sizes
May 29, 2010 | Weber Genesis Silver A Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
My silver c igniter does not work..need to manually light..burners work..is new igniter worth pruchase? grill is almost 6 years old
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Jul 18, 2009 | Weber Genesis Silver C Grill
Weber Genesis Silver C Grill Logo
710 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
