Question about Kalorik (TO-17443) 2-Slice Toaster
Hi, my kalorik toaster handle won't stay down.Is there a website to repair it?
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
Wont stay down
At the moment I am looking for the problem in m,y Tefal. The biggest problem seems to be sorting out how to pull it apart. I have sfound that the whole carriage must be pulled out the back of the toaster. About 10 T10 screws to be removed from the base then there are are a couple more philips screws to remove after the back is off, then the handles that you press down to allow the bread to drop mus t be released. There are plastic pieces that hold in the metal tip on the handles. They are located inside the body and are accessewd from the slot that the handle moves in. I haven't yet located the release clips for the high lift handles. Once I have found them I may be able to access the mechanisms. If this doesn't help enough then please ask for more information as I shall have found my way inside by then
billypil
Jul 12, 2010 | Tefal Avante Deluxe 4 Slice Toaster
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
KitchenAide Toaster
Kitchenaid does not recommend repair on the toasters, as it is not cost effective for the consumer or company to engage in repair.
I would recommend calling Kitchenaid Customer Service. If the unit is within the 1 Year Warranty, they may replace it at no cost. If the unit is outside of warranty, they may provide discounts on the purchase of a new toaster.
Their toll-free telephone number is 1-800-541-6390.
Apr 10, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Toaster
Sounds as if the small retaining clip has worn out or maybe even broken off!!!
Is the machine old or fairly recent?
May 20, 2008 | Waring WCT805 4-Slice Toaster
Kalorik (TO-17443) 2-Slice Toaster Logo
80 people viewed this question
Top Kalorik Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kalorik Kitchen Appliances - Other Expert? Answer questions, earn points and help others
