Question about Lands Phones
My Siemens Gigaset 8800 has two phone lines but one line has ceased working. Any ideas?
  • 4,102 Answers
Hi, Is it an extension phone thats not working or is it the main phone that plugs into the socket.
If its an extra phone then you should un-plug for a few mins then try again.
Posted on Apr 26, 2008
    Genius:
  • 3,587 Answers
Hmmm...nothing on that line at all..was it starting to falter prior to the absolute failure mode? also, any indication from the set that the line is active?
PURCHASED USED SIEMANS 8800 HAND SET ,REPLACED BATTERY,AND RESET PIN TO DEFALT 0000, PHONE FLASHING "SEARCHING" .HOW DO I GET THE HAND SET TO SYNK UP TO THE BASE STATION?
You need to register the handset to your base to get the phone to work to do this follow the steps in the manual. If you do not have the manual go to the link below and scroll down to product detail then click on the blue product manual.
Gigaset-Accessory-Cordless/dp/B00005UFDR">http://www.amazon.com/Siemens-8800-Gigaset-Accessory-Cordless/dp/B00005UFDR
Or look below to learn how.
Jun 03, 2011 | Siemens Gigaset 8800 Cordless Expansion...
WON'T REGISTER TO THE BASE
Did you go to gigaset support site? Siemens had turned support over to a third party and most times can answer questions.
Mar 20, 2011 | Siemens Gigaset 8800 Cordless Expansion...
Cordless phone won't charge.
take a pencil eraser and clean off the contacts on the cradle and one the phone itself, they may just be dirty.
May 27, 2009 | Siemens Gigaset 8825 Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Jun 15, 2008 | Lands Phones
Siemens Gigaset 2420 tow line phone system
Contact 888-286-9375 Siemens Repair Line. Should be able to help you.
Jul 21, 2007 | Siemens Gigaset 2420 Cordless Phone
Line cut off problem
That is a common problem with this model, normally happens after a storm passes through. Unfortunately there is no easy fix for on site, it would need to be sent in for repair or replaced. You can google Siemens Cordless Repair to find service facilities.
Dec 18, 2006 | Siemens Gigaset 2420 Cordless Phone
Lands Phones Logo
75 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
