Question about Sony Playstation 3 (PS3) Console
My playstation 3 works on my downstairs telly, however does not work with any of the upstairs televisions. the problem began when i first bought a HDMI cable. the problem is that no picture or sound can be seen or heard. why and how do i fix it ?
    President:
  • 1,139 Answers
It is probably due to the fact that your PS3 needs resetting back to standard definition. Try holding the power button down for 5 seconds until it beeps. It should then revert back to standard.
Hope this helps
Posted on Aug 06, 2010
Not enough heat
Take an Amp draw on all heaters and compare. If within 5%, they are working fine but you may have more open area downstairs than up.
Mar 03, 2010 | Heating & Cooling
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
www.jollygreenplumbingmachine.co.uk
Dec 26, 2009 | Desa International CBN30T Central Heating...
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Mr Slim Model PEH3VK no air in one zone.
The Zone controller needed replacing so I rang for a Serviceman
Jul 06, 2009 | Mitsubishi Heating & Cooling
3 out of 7 rads working with hot water
This is a flow problem within the system and you have ruled out the two major problems already.
asuming the pump has been fitted in the correct way round and the pump isolation valves are open fully. have you tried closing down the radiator valves upstairs and forcing the flow around the downstairs circuit? also is there any zone valves on the circuit not opening.
Is it a conventional type system with a header tank ?
Feb 01, 2009 | Heating & Cooling
D-Link DIR-628 router, i've lost internet connection to the PC!
You would be best to buy a wireless router with a built in modem, this would be much easier for you to setup and manage
Nov 16, 2008 | D-Link AirPlus DI-524 Wireless Router
PS3 tv display
It appears that the problem of electromagnetic waves. Somewhere there are a source of radiation that the real problems ps3 and television
Jul 01, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
