Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
How do i get my hp pavilion zv5000 to run on ac power only. it will only run on the battery.
  • 22 Answers
Zv5000 Laptops are plagued with problems related to the jack on the back of the computer. After prolonged use the jack tends to make the solder joint loose. Jacks can also go bad. The solution would be to check if the power comes on momentarily when wiggling the plug in the jack, if the power comes on intermittently then chances are you have a loose solder joint and may need repaired by a qualified tech. Fortunately, for the technically savvy this may be done carefully provided the proper static sensitive precautions are taken, due to the fact the computer must be totally dismantled to get to the jack and properly inspect the solder connections and repair or replace the jack. Silver heat sink compound must also replace the silicone on the processor ( one dab and compress, do not spread compound!) The jack need should it be replaced can be found on Ebay
Posted on Aug 31, 2010
  • Radiojunkie Sep 01, 2010
    The stock power supply provided by HP also has a flaw. The two contacts inside the plug tend to bend inward and/or corrode with black oxidation preventing a good contact. These may be cleaned carefully ( with unpluged power supply) with a small alcohol wipe and a jewelers screwdriver or pin.
My boyfriend has a HP Pavilion ZV5000 laptop running Windows XP. Everything loads fine. then he trys to log into his user name, puts in the password... it sais loading your personal settings, then the...
Starting point would be to turn the computer right off including taking out the battery unplug the power supply wait a while and then reconnect power supply and restart holding down the key that allows you to enter the BIOS. Reset the BIOS to default settings and then restart. If this works then reinsert the battery and hopefully this will fix your problem.
Sep 11, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
ZV5120 pavilion notebook powercord not connecting
You can get an exact adapter from eBay link below, they are quite cheap. Sometimes the break is close to the end of the plug, and sometimes, the actual solder on the socket inside the unit is fractured, causing intermittent connections. Often we are able to use the old cord Plug, and graft on the new power Lead. However it is wired and regardless of how many wires are inside, the is only One - Negative, the OUTER contact. The INNER Contact is Always + Positive, sometimes there are three wire inside, TWO are Plus, and ONE, the shield, is negative.
http://shop.ebay.com/i.html?_nkw=HP+Pavilion+zv5000+power+supply+&_cqr=true&_nkwusc=HP+Pavilion+zv5000+power+supplly&_rdc=1
Mar 15, 2010 | HP Pavilion zv5000 Notebook
Hp pavilion ZV5000 was working fing, now it does not start, no lights, with A/C adaptor or battery, wonder if this is a common issue that others have seen.
Yes it is. You either have a bad AC adaptor or a bad internal power supply. My guess, the power supply.
About a $300 fix when sent back to HP. I fixed mine once. Next time its a new computer.
Nov 17, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zv5000 - No power with battery in.
the jack is the problem it is not getting enough power to laptop
Nov 02, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Ac power only
Make Sure The Battery Is Making Good Contact With The Metal Prongs. It Must Not Be Making Good Enough Contact Some People Have A Good Result From Sticking Penny In The Battery Compartment To Press The Battery Against The Contact. Also You May Try Bending The Contacts Toward The Battery.
Feb 10, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP PAVILION
please go through this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372748&lc=en&cc=us&dlc=en&product=499234&rule=20094&lang=en
Aug 12, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
How do you restore factory settings on a hp pavilion zv5000
I have the same problem - Best Buy does not give back-up discs,..but will allow you to purchase them (not cheap). I was used to them coming with my computers.
Apr 24, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Nov 21, 2007 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
    175 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
