Question about Cell Phones
H. My Blackberry 9700 constantly switches between headset and handset during calls. It is however stable when using the headset. How do I fix the switching? Regards, Kjetil, norway
  • kjetil_borsu Aug 06, 2010
    Thanks! This was helpful, and the response was very quick.
  • 677 Answers
Hi, is the phone switching off and on when making calls?please reply.thanks
Posted on Aug 05, 2010
  • kjetil_borsu Aug 05, 2010
    Hi, the phone does not switch off and on when making calls, just switching between handset and headset during calls, as indicated on the screen where the upper left symbol switches between the "call" and "handset" symbols.
  • ikechukwu joshua
    ikechukwu joshua Aug 06, 2010
    Ok, it's network signal failure. Due to phone board malfunctioning it's a hardware fault. It will require attention from a skill personnel.
I want to connect my nokia BH-104 headset tp my blackberry bold 9700 phone. Please guide
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Mar 20, 2011 | Nokia BH-104 Bluetooth Headset
    I have blackberry bold 9700 (T-Mobile). I MEP2 (network): 030611 ........... mep3: 732967 .................... mep4, mep5 ......... but: enter network mep code (0 left):...
    You need to reset the Counter MEP 1...
    Blackberry solution for mep code (0 left)
    This is the solution for anyone have mep code 0 left in his handset that no attemt balance for enter code.
    1. Please install black berry desktop manager. (its free download from black berry website)
    2. Connect handset with pc.
    3. Open this software its shows booting rom and ask u phone unlock code(note: its not asking mep code just user code).if not phone code inserted then it update rom automatically.
    4. Now your handset reboot, then you got mep code(10 left) in network lock section.
    Download Rom Booter:
    RapidShare: Rom Booter
    Then Unlock it using the Unlock code at here
    http://www.theunlockarena.com/blackberry-9700-blod/rs13wp9/
    Mar 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
    How do you pair with blackberry 9700
    Once you make your Blackberry discoverable, then put the Plantronics M100 headset into pairing mode by holding the call control button until the headset flashes red and blue. Below is the link below for the M100 user guide with the pairing instructions.
    M110 User's Guide
    Good luck from Headsets Direct!
    Feb 27, 2011 | Plantronics M100 Bluetooth Headset
    I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
    Hi,Instructions on how to pair blue tooth device with black berry.
    Pair Your Blackberry with a Bluetooth Headset
    Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
    Use your Bluetooth Headset with your Blackberry
    Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
    Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
    Press the on/off button on your headset to end a call or use the end button on the handheld.
    Tips & Warnings
    Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
    Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
    Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
    Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
    Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
    Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
    Have a nice day .
    Feb 16, 2011 | Jabra BT125 Headset
    During phone calls my blackberry curve 8520 keeps switching from handset to headset mode every second.i am unable to listen to what the other person is talkng
    Remove off the battery and keep aside checck your memory card for errors or virus if ther was any downloading done recently
    Now replace battery and restart. If the fault stays you will need to reinstall.
    Sep 28, 2010 | RIM BlackBerry Curve 8520 Smartphone
    How to stop my Blackberry Bold 9700 from constantly switch between headset and handset during calls
    I am having the same exact problem with mine. The last time that it happened all that I had to do to correct it was plug the headphones in and then take them back out and it fixed the problem. Now it is doing it again and nothing that I have tried is working!
    Jul 04, 2010 | RIM BlackBerry Bold 9700 Smartphone
    Blackberry sound not working
    Same problem here with a BlackBerry 8830. Elsewhere found a solution for another model that worked for mine:
    1) Plug in headset.
    2) Turn off BB.
    3) Remove phone battery.
    4) Reinstall battery and let phone restart.
    5) Remove headset.
    Nov 29, 2008 | Cell Phones
    Cell Phones Logo
    29 people viewed this question
    Top Cell Phones Experts
    Marvin
    Marvin
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
