Question about Bosch 13624 24V Cordless Hammer Drills
How to fit a bosch keyless chuck - Bosch 13624 24V Cordless Hammer Drills
  • 90 Answers
Remove the old one. check inside the throat of the chuck to see if it has a screw. if it does turn it left to right. if no screw good. take a very large allen wrench and place in chuck tighten it. place it on a flat surface, bench edge, where the chuck is free. lift the allen wrench up higher than level and take a large hammer and hit it down hard. this will break it loose from the spindle. when you go back with the new one put never seize or grease on it some it won't bind. next time you change it it will come off easier.
Posted on Aug 31, 2010
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Replace Keyed Chucks with Keyless Chucks
Can't help with this other than suggest that you do not proceed, Keyless chucks can be problematic particularly if dust /debris from material being drilled finds its way into the chuck..
Mar 30, 2017 | Drills
Require a 10mm and a 13mm Male-fitting Keyless Chucks
I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
Apr 04, 2017 | Drills
I have a rotozip 20 and the new keyless chuck just does not work. Am I doung something wrong?
Try not inserting the bit all the way in until it bottoms- it should not bottom. Also make sure it is the correct size range for the bits you have.
Feb 10, 2012 | Bosch Drills
Connnect drill to keyless chuck bosch 36vfl1
Push or pull the business end toward the body while gently pressing and rotating the bit into it. The chuck will snap back up to retain the bit when you have it lined up right.
Sep 19, 2009 | Bosch 36V 1" Sds - Plus Rotary Hammer
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
May 04, 2009 | Makita Drills
Let the expporte of carte mimory
hello!
put head set on the chuck,or get a set of jack cable one end fit to chuck make it tigh and other jack cable the red on amplipier w/ 500 watts power
and black one on video of your tv set.cheers
Apr 29, 2009 | Bosch 1/2" 6.5 Amp High Speed Drill With...
My rotozip RZ20 keyless chuck will not open.
open the chuck and look in the center there is a screw allen type most times or a star screw in the middle that connects it to the drill shaft just tighten it up should work fine then!
Apr 27, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Bosch 13624 24V Cordless Hammer Drills Logo
448 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Are you a Bosch Drill Expert? Answer questions, earn points and help others
