Question about Hotpoint NLL113EYWO Electric Dryer
Maytag gas dryer -
The dryer is not drying. The gas valve doesn't seem to be opening after the first cycle and makes a slight rattling sound when it seems to be trying to open. Is there such thing as an intermittent valve? The solenoids ohm out ok.
  • 550 Answers
Http://www.askmehelpdesk.com/attachments/appliances/5300d1195349678-no-heat-maytag-dryer-ldg7304aae-dsc03340.jpg
there are several subsystems that turn off the gas if they fail,
thermal overload fuse, shuts off the gas
Igniter system includes heat &or optical flame sensors that turn off the gas if igition fails.
the image above shows igniter and optical flame sensors on the end of the gas line inside the duct,
Before testing any igniter parts turn off the gas at the shutoff( the gas is on when you try to run the dryer right (dumb Q 101))
  • Igniters glow brightly, if the ohmmeter reads high the igniter is likely failed should be visible when the system is first turned on & in a heating cycle
gas solenoids do fail as previously noted
- gas solenoids do not switch on until the igniter has reached operating temperature, and clilcked off, so any problems in the igniter or optical sensors show up in the gas valves as well
Posted on Jun 26, 2008
    Genius:
  • 1,028 Answers
Still may be solenoids belive it or not the coils could become weak and fail to pull open valve recommend changing both at same time
Posted on Apr 27, 2008
Dryer spins,screen clean,exhaust open blows good no heat
Check the coils on valve or the igniter. Access both thru Access panel on lower right of front panel. Set heated dry cycle & start, igniter should glow bright followed by a "Click" sound, which is valve opening. If it glows and no click, replace the valve coils (2 donut looking objects on top of valve). If no glow, replace igniter, usually just unplug to remove, carefully, they are ceramic and break easy.
Feb 13, 2011 | Maytag MDG2600BWW Gas Dryer
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
My Maytag DG712 dryer does not dry the clothes. The burner comes on when it first starts and then shuts off after several minutes. After about a minute it restarts but only stays on for about another...
If you have a gas dryer..
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 16, 2010 | Dryers
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MDG7600AWW not staying hot
Hi, It sounds like that the coils on top of the gas valve are not opening the valve later in the cycle. They get weak enough ovwer heat and will not open the valve. You can listen for the ignitor to click on and then you can hear the gas ignite. If late in the cycle you hear the igniter click and then no gas ignition, change the coils.
You should also make sure the vent going to the outside is clear of any lint or kinked.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 13, 2009 | Maytag MDG7600AW Gas Dryer
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Hotpoint NLL113EYWO Electric Dryer Logo
165 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
