Question about Maytag MTF2156GES Top Freezer Refrigerator
Freezer is working but lower cooler is not. did hear a clanging noise befor the lower unit gave dup?
  • 869 Answers
Check for a bad heater ... remove plastic floor inside of freezer and ohm the heater ... Please rate this ..
Posted on Aug 06, 2010
SOURCE:
HOW DO I FI THIS?
Will it not cool? Your question is not specific
If you need further help, I’m available over the phone at https://www.6ya.com/expert/conrad_31509e768082a712
Jan 16, 2015 | Refrigerators
Fridge water sound
This kind of noises produced gas in cooling system.
In the old coolers never heard sounds like streaming water because the compressors were very loud due to high pressures (12 bars or more), which were required for efficient cooling. Today we use more ecological gases which work (from 5 to 6 bars) at much lower pressures, thus compressors produce much less noises and now suddenly we hear sounds that never before heard. Generally speaking noises is lower, measured in decibels.
Dado
Feb 01, 2014 | AEG Freezers
I have a GE Profile Side by Side TPX21PR/Tpx21BR. The freezer is not freezing ice cream or even bread, but the meat seems fine. There has been a loud noise emanating from the unit for over a year.
Kindly provide few more details so that i could provide more appropriate solution to your problem :-
1. How old is the unit?
2. Kindly hear the noise - Is it from the freezer section or upper back or lower back of the refrigerator?
3. Do you hear the compressor running?
4. Any problem with temperature in lower section or is it limited to freezer section?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 21, 2011 | GE Refrigerators
We have a samsung side by side fridge freezer dispenser model and the fridge side has stopped working but the freezer does appear to still be functioning. The fridge temp control keeps restting itself to...
Hi. If you remove the light unit ond the lower casing which has four screws two of which are under the small vent covers that unclip. The light unit by the way has two screws under the difuser and that unclips. Mark the top before removeing with tape to give ease of replacement. After removing the top light unit inside the fridge and unclipping the two electrical terminals it can be removed. The same is true for the lower unit. Be aware the lower unit will be frozen in place. Ease it away to break the ice seal and remove the electrical connections. Use a hairdrier on full powar to fefrost the cooler unit at the rear of the fridge. Use the same method to defrost the removed fan unit. Pay attention to the fan drain. It may need the insulation trimming to make it drain and work again when re installed. Cut it away with a craft knife. When it is dry and defrosted re install in using the reverse procedure. Be aware it will frost up again and need you to do the whole thing again as soon as the fan gives signs of fouling on ice. You will hear it catch. Regards. Paul.
Mar 16, 2010 | Samsung RS2630SH Side by Side Refrigerator
My Vintagekeeper Tuscany 220 wine fridge is making lots of unnecessary noise.
Hello, this is a common problem when parts start to wear in the motor. They rattle and clang allover the place, depending on age of fridge you can get the motor replaced and regassed. Or depending on age it may be time to replace the fridge. I hope this is of some use.
Nov 04, 2009 | Vintage Keeper Koolspace chillR Cooling...
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Maytag MTF2156GES Top Freezer Refrigerator Logo
55 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
