Question about Whirlpool LER5636P Electric Dryer
My whirlpool duet dryer is not getting hot but it is running
  • 5,911 Answers
If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat.
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
On a Whirlpool Duet or Kenmore Elite model, the heating circuits are located inside the dryer under the dryer drum on the right hand side. You will need to remove the lower toe panel under the door to access. The toe panel comes off by locating and removing the screws under the bottom front edge of the panel. The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals (all the way towards the back of the dryer cabinet). The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) may be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.
NOTE: The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
If you have any questions, please post back with your MODEL NUMBER (located around the door opening) and let me know. I hope you find this information helpful.
NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Posted on Aug 05, 2010
My duet drye will not get hot but runs
check your heating element if gas test regulator
Aug 25, 2012 | Whirlpool Duet WFW9550 Front Load Washer...
I have whirlpool duet gas dryer. It is leaving brownish moon shaped streaks on my white clothing. I have looked inside and cannot find anything that looks like it is causing this. Can you help?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 15, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
My whirlpool duet electric dryer will turn on run for a minute than turn off and smells hot
Check the dryer vent,some times they will get stopped up with lint causing the dryer to shut off on high temperature.
Mar 03, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer runs but will not get hot
hi crich... generally when the dryer will not get hot the heating element is bad and must be replaced. Joe
Thanks for choosing Fixya!1
Feb 24, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool duet is not drying....it is not getting hot. It appears to be drying but it is not getting hot. I have to run the dryer multiple cycles.
Check for crimp in your vent line, Check your breaker. It is a dual breaker if one side pops it will run with no heat. Check those first.
Aug 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LER5636P Electric Dryer Logo
3,909 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
