Question about Directed 04' and Up Chrysler Sentry Immobilizer Interface for Remote Start (556CW)
Chrysler Sebring ECU replacment - Mitsubishi Computer
I replaced the ecu in my 2001 chrysler sebring 3.0L and it is a misubishi ecu. When I installed it the car will not start. I beleive it is a immobilizer issue. Does anyone know of a relearn procedure i can perform rather than taking it to a dealer. I would greatly appreciate it. THanks!!
  • 87 Answers
There is no relearn procedure you can do yourself you need a scan tool and the PIN number to transfer the security numbers to the new ecu.
Posted on Sep 26, 2009
2004 3.3 liter chrysler t and c sebring van wont start. cannot get fire from coil to plugs and have replaced all those parts
The ECU module controls the spark. If you have a bad crank sensor. no spark even with a good ECU.
Aug 26, 2017 | Chrysler Cars & Trucks
The easiest way to take off a water pump for 2004 Chrysler Sebring
Take it to a garage and say "put a new water pump in this for me".
2004 Chrysler Sebring 2.7Ltr. Water Pump Replacement ...
z? 29:29 https://www.youtube.com/watch?v=ebeXcNmBnnE Sep 19, 2015 - Uploaded by Paul Veltum In this video I'll walk you through replacing the water pump on this 2004 Chrysler Sebring with it's 2.7 ...
2004 Chrysler Sebring Timing Belt Water Pump Before 90K ...
2q==? 13:03 https://www.youtube.com/watch?v=UQHRa28sRkY Nov 25, 2012 - Uploaded by Mastermind Denver This video shows why we at Mastermind Enterprises Auto Repair Shop in Denver recommend replacing the ...
WATER PUMP REPLACEMENT IN CHRYSLER 2.7L ...
9k=? 4:52 https://www.youtube.com/watch?v=z_QrXR2jcb8 Mar 7, 2014 - Uploaded by kzguy2 2008 Dodge Charger 2.7l was in need of a new water pump due to it leaking. ... 2004 Chrysler Sebring 2 ...
2004 chrysler sebring water pump weep hole inspection ...
2q==? 0:15 https://www.youtube.com/watch?v=wzqHaQ40doQ Feb 26, 2014 - Uploaded by Graeme Tolton 2004 chrysler sebring water pump weep hole inspection with borescope. ... 2004 Chrysler Sebring 2.7Ltr ...
Chrysler 2.7L Water Pump Installation Problems - YouTube
9k=? 3:30 https://www.youtube.com/watch?v=h5_VFJ1gCpI Nov 19, 2014 - Uploaded by South Main Auto Repair When I installed this water pump on the 2006 Chrysler Sebring 2.7L I ran into a ... 2004 Chrysler Sebring 2 ...
Feb 15, 2016 | Chrysler Cars & Trucks
Windshield wipers stop working when the defroster is on
The only thing they have in common is the ignition switch.
Dec 18, 2015 | 2007 Chrysler Sebring Sedan
Bus sebring
No "bus" means no communication to or from the ECU. You need a ECU computer for your car.
Jan 01, 2014 | 2009 Chrysler Sebring
Timing specs 2000 chrysler sebring 2.5
you cant change the timing yourself its ecu controlled.
Aug 11, 2012 | 2000 Chrysler Sebring
Ecm ecu computer is out on 99' chrysler sebring lxi
I have the same problem with my 99 sebring lxi, I'm getting a new ecu for the transmission and the engine, hopefully that fixes it. Did the car randomly die and wouldn't start again or when driving keep the transmission in one gear and wouldn't change?
Jan 17, 2012 | 1998 Chrysler Sebring
2001 chrysler sebring leaking water beneath thermostat housing through a factory hole , I changed thermostat and gasket no change
This is called the water pump weep passage which is a sign that your seal in the water pump has failed.
You need to replace the water pump.
Sep 15, 2010 | 2001 Chrysler Sebring
Tire specs for 2001 chrysler sebring
HI. Here is the complete line up of specs concerning your vehicles front and rear tires. You did not post the trim line of this car, so I posted all models and tire combination's specified by the manufacture.
2001 Chrysler Sebring Lim 2 Door Convertible Front and Rear Tires P205/60R16
2001 Chrysler Sebring LX 2 Door Convertible Front and Rear Tires P205/65R15
2001 Chrysler Sebring LX 2 Door Convertible Front and Rear Tires P205/60R16
2001 Chrysler Sebring LX 2 Door Coupe Front and Rear Tires P205/55R16
2001 Chrysler Sebring LX 4 Door Sedan Front and Rear Tires P205/65R15
2001 Chrysler Sebring LX 4 Door Sedan Front and Rear Tires P205/60R16
2001 Chrysler Sebring LXi 2 Door Convertible Front and Rear Tires P205/60R16
2001 Chrysler Sebring LXi 2 Door Coupe Front and Rear Tires P215/50R17
2001 Chrysler Sebring LXi 4 Door Sedan Front and Rear Tires P205/60R16
Jul 06, 2010 | 2001 Chrysler Sebring
I have a 2001 Chrysler Sebring LXI Coupe 3.0 mitsu engine, front O2 sensor replaced due to code on computer said to replace, code won't reset. Autozone says O2 sensor has a fuse but they don't know...
A great tool to have that can save you some money to read computer error codes and clear them after work has been done can be had for under $100 from Actron. This is what I have been using and its a life saver but it's also good to have the vehicles repair manual as well.
The computer on this car is OBDII like many other vehicles out there these days so you'll need a tool that can plug in and read the outlet located above the shin of your right leg under the dashboard or steering wheel. Here is a link to a bunch of their products on amazon Actron and other OBDII Computer diagnostic code reader tools.
Dec 26, 2009 | 2001 Chrysler Sebring
2001 sebring 2.7l runs perfect ice cold but as
Your temp sensor is the fault. Replace it and problem solved.
The sensor is telling the ECU (brain) that the engine is cold even when it is hot.
Regards
Lloyd
Dec 09, 2009 | 2001 Chrysler Sebring
Directed 04' and Up Chrysler Sentry Immobilizer Interface for Remote Start (556CW) Logo
544 people viewed this question
Top Directed Computers & Internet Experts
David Payne
David Payne
Are you a Directed Computer and Internet Expert? Answer questions, earn points and help others
