Question about E-Machines eMachines Desktop PC
The computer is turning on, but the monitor wont. the monitor keeps saying it in "power saving mode".
  • swufabuda
    swufabuda Aug 06, 2010
    What is the make and model of your computer?
  • E-Machines Master
  • 5,660 Answers
Perhaps the computer is Not turning on at all, and only seems like it is. Monitor's will go to 'Power Saving Mode' due to No Signal.
No video signal.
The computer isn't sending a video signal to the monitor, therefore the monitor goes into a power saving mode.
I suggest first checking the monitor cable, if it is a detachable unit. Use a Known to be Good monitor cable in it's place, or use the monitor, AND the monitor cable, on a computer that is known to be good.
Cable checks out?
Then I suggest cleaning out the inside of the computer, if the computer is dirty inside, and also the Power Supply.
Use a can of compressed air for computers.
[Attach the plastic straw provided with the can of air, to the can of air's nozzle.
When you go to clean out the inside of the Power Supply, you will have to use the plastic straw, through the ventilation holes in the Power Supply's case.
Hold on to the plastic straw with one hand, use the other hand to hold the can of air.
The plastic straw can shoot off of the can of air's nozzle, and wind up inside the case of the Power Supply, if you don't.
Real riot trying to fish out the straw ]
The above is a prerequisite before working on the computer.
Also heavily suggest you observe Anti-Static Precautions BEFORE you reach inside the computer.
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Relieve your body of Static.
Computer off, UNPLUGGED from power, computer on a table, computer case open.
TOUCH the metal frame of the open computer case, to relieve your body of Static.
Should you get up, and walk away in the middle of working on your computer, upon your return be SURE to touch the metal frame again ]
Problem could be with the 'graphics engine' of your computer, but experience, and observation through the years makes me lean more towards a bad Power Supply.
['Graphics engine'. The GPU. Graphics Processing Unit.
Can be Integrated Graphics, or a dedicated graphics adapter card.
Integrated graphics is also known as OnBoard graphics.
On the motherBoard.
The GPU is soldered to the motherboard.
A dedicated graphics card, (Graphics adapter card), has it's own GPU.
http://en.wikipedia.org/wiki/GPU
Weak Voltage power rail.
[Voltage Power Rail:
The Power Supply in your eMachines computer, converts AC electricity from your home, or business, to DC electricity.
(An example of stored DC electricity, is a D cell battery used in a flashlight )
There are three main DC voltages produced,
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
(Two D cell batteries produce 3 Volts DC)
Each of the Voltages indicated above emit from one power rail, inside the Power Supply.
The 3.3 Volt has it's own power rail, same with the 5 Volt, and the 12 Volt.
(Your eMachines power supply, does not have multiple 12 Volt power rails. Unless it isn't the stock power supply that came with the computer ]
http://en.wikipedia.org/wiki/Computer_power_supply
1) ALL the LED lights combined, use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts. (Less for older Processors. Such as Pentium III's for example)
With a power supply that has a weak voltage power rail, the lights will light, the fans may spin, (Or spin a few times then stop), but the Processor won't have enough power to turn on.
Lights, and fans can spin all day, the Harddrive may sound like the Platters are spinning inside, but if there is no Processor operating, there is No computer.
[Information on Harddrives, and the aforementioned Platters,
http://computer.howstuffworks.com/hard-disk.htm ]
Suggest you check the voltages produced by the Power Supply, or use a Known to be Good, Compatible power supply for a test unit.
[Compatible:
Right size, and shape of power supply case.
Correct amount of power cables, and the correct power cables,
http://www.playtool.com/pages/psuconnectors/connectors.html
For any questions regarding any of my statements above, please post in a Comment.
Posted on Aug 06, 2010
Flatron W2353 monitor wont turn on
LG W2353 dvi power saving mode
how to fix ?
Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
Analog power saving mode
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
Oct 31, 2009 | LG 22" FLATRON LCD Monitor
Power saving mode
Prevent the laptop/desktop monitor from going to power saving mode:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 04, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
    Analog power saving mode?...
    I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
    May 13, 2009 | LG 22" FLATRON LCD Monitor
    MY DELL SE198WFP GOES TO POWER SAVE MODE AFTER 2 SECONDS
    I had this problem as well as a lot of other people. The solution is to go to the power options in the control panel and turn power saver off. This should keep the monitor from going into power saving mode.
    Dec 29, 2008 | Dell SE198WFP LCD Monitor
    E153fp goes dark into power save mode after Windows start up
    may be your power saving option have small time .
    check in control panel power option check power shemes.set it to 20 minutes.
    Nov 27, 2008 | Dell E153FP 15" LCD Monitor
    In power save mode
    The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
    Nov 17, 2008 | Dell E173FP 17" LCD Monitor
    E-Machines eMachines Desktop PC Logo
    128 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
