Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
How do you get the impellar off? - Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
  • 106 Answers
First, separate wet end of pump from motor.If not already off, take diffuser off. Remove back cover of motor and hold center shaft with either a wrench on the flats of the shaft or a large screwdriver on the end of the shaft.(It all depends on which motor you have.) Then just unscrew impeller. (Some larger hp motors have a reverse threaded screw holding impeller also.) You may need a large pair of pliers but be careful not to score the impeller.
Posted on Aug 05, 2010
Why is the motor roaring ? is it rubing on housing or a bearing ?
It may not be you motor, but the sound of some item caught in the impellar, which is the part that causes suction. It is usually located in the upper housing, and can be accessed fairly easily. Unscrew any visible screws,(usually phillips type) and carefully lift housing off. This should expose the impellar. If debris is present, remove it.
But also check for possibly broken fins on the impellar itself. Sometimes items like coins, or nails etc, will get picked up accidentally, then spin around in the impellar housing, only to break a fin or two trying to move on. If this has happened, replace the impellar.
Dec 22, 2015 | Hoover UH70105 WindTunnel TSeries Bagless...
Trying to fix the impeller
Take the unit to a mechanic with an air wrench or buy an electric impact wrench.
Gary @ Fix Ya
Dec 08, 2012 | Garden
Error code F 35
F35 is a slow drain error check for kinks or cloggs in the drain line. Also check that the pump is not clogged and while checking the pump check the impellar on the pump that no impellar blades are missing as well. broken fins on the impellar or if the impellar is not spining would give you the same fault pump error if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 11, 2011 | Kenmore Washing Machines
My Pentair WF-26 1.5 HP just started emitting a loud "whine" detectable above the regular pump noise. Looking through the window into the debris basket the water also looks more frothy than...
The loud "whine" you hear, does it sound like its a metal kind of "whine"? There are a couple of things it could be. Your impellar may have debris caught in it and to properly check and clean the impellar you will need to open up the pump and remove the diffuser and check/clean as needed. You can sometimes remove the basket and try to feel your way with a couple of fingers to the impellar but your only able to reach 10% of it. Whisperflo is an outstanding pump but very notorious for debris getting stuck in the impellar and the impellar breaking easily because it is plastic. If you have ran the pump without prime/no circulation you can easily have caused heat damage to the impellar. The other thing to check is the motor. Although it is only 2 1/2 years old the motor still could be going out. The bearings are the top noise makers when a motor is going bad. You will still have normal suction/circulation it will just be really loud when the motor runs each day.
I hope this helped. Please don't hesitate to submit any further questions you may have. I would be glad to help.
Dec 07, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
Replaceing the wet end seal on my hot tub
disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
Jandy jhp .75 hums when you turn it on does not pump
It sounds as if motor is spinning and pump is free so the impellar must not be attached to the motor shaft. There is a set screw on the impellar to hold it to shaft or the pump impellar could be cracked. Only way to tell is take the impellar housing off.
what kind of motor or pump? Hayward, pac flo?
May 28, 2009 | Plumbing
Replace impellor in yamaha 2 cylinder 40hp outboard motor
take all bolts out on foot were the two mate drop lower unit down pull impellar cover will be plastic some what roun with a short molded inlet on top when u remove impellar be sure not to lose the key way and when u put the cap on the impellar be sure to rotate it so blades will ben\d in place make sure u dont pintch them when u bolt the cover down MAKE SURE WHEN YOU PUT THE FOOT BACK ON TAT YOU LINE UP THE IMPELLAR INLET WITH THE ONE COMMING DOWN FROM THE ENGINE LINE UP YOUR SHIFTER LINKAGE (TOWARD THE TRANSOM IS WERE IT IS LOCATED bolt it up test with a hose should be good
May 12, 2009 | Boating
I have a personal watercraft jet ski kawasaki 1100zx1 and the impeller shaft is frozen. It won't turn. What might be the cause?
only 2 things could be wrong seized motor or bad impellar bearing it is located in the impellar housing you really need to pull the whole impellar housing out of the back of the ski to find out witch one it is
Apr 27, 2009 | Yamaha 12V Air Pump
Suzuki 4hp two stroke impellar
Dropp the lower unit, should be only 4 bolts holding it on. Impellar housing should be located right on top of the lower unit. four screws it the housing slides off the shaft, insall in reverse order with ne gaskets, make sure you re- align the waterhose/pipe from the lower unit back to the head
Mar 22, 2009 | Boating
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
128 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
