Question about Garmin GPSMAP 182C GPS Receiver
My garmin 182c doesnt start up. There are power and the external fuse is ok. Is tehere some internal fuse as well?
WONTREADBLUECARD
Hi, check if the card reader is OK , the slot must have good contact with the card, if there is bad contact it will not work.
Jan 03, 2014 | Garmin GPSMAP 182C GPS Receiver
My garmin gpsmap 182c works when I have the consol tilted on my boat but the turns off when I tilt the consol back down
Possible loose socket connection or power wire broken inside power cable. Bend the power cable with your hand while the unit is on and try to reproduce the problem
Jul 02, 2013 | GPS
Garmin went totlly blank during use.is there a
most Garmin's are powered by external sources which charge the device. the device has a battery internally and is kept charged by such a cable connected to the cigarette lighter socket.
If its a built in Garman then most likely its the fuse.
AndystUK
Aug 30, 2009 | Garmin nuvi 350 GPS Receiver
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
Gpsmap 182c
My 182C developed the same problem. It appears to be a problem with reading data from the card. When I power up the unit, sometimes it will display "Reading Card" for a long time and no data will be read. I've found that if I open the latch and push in on the card as I press the power button, it will only then display the number of maps loaded. Sometimes less than other times. Most times a lot of data is not loaded from the card causing the problem frankcps describes and other problems, such as no data for tide stations, anchorage, etc. I tried cleaning the contacts on the data card & where it plugs in, but still continue to have the problem.
Jul 26, 2008 | Garmin GPSMAP 182C GPS Receiver
Instruction manual
If you need manuels for any Garmin unit, just go to www.garmin.com, click on support, search for your model and click on it.
Jul 14, 2008 | Garmin GPSMAP 182C GPS Receiver
Garmin GPSMAP 182C GPS Receiver Logo
41 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
