Question about Cameras
I don't know where the shutter button is in the canon camera EOS Rebel X s
  • 2,016 Answers
There is a manual available here.
Posted on Apr 27, 2008
Why does my canon eos rebel t3 not take a picture when the shutter button is depressed but tje red eye reduction button keeps flashing and the video still works?
Usually, it means that the timer function has been turned on, and the camera is going through a countdown to trigger the shutter.
After that, it means that something else is not working correctly. If video works and records, then you know that the sensor and memory are functioning correctly. At that point, check to see whether your camera and lens are set for the form of autofocus or manual focus you want and that the aperture is still functioning correctly.
At some point, switch the camera to an all manual settings mode and try the shutter switch. If it still does not take a picture, the switch may have a problem.
Aug 18, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Tip
Canon Rebel XS Firmware Update MAC Models: Canon EOS Rebel XS / Canon EOS 1000D...
Solves: BUSY Error & Error 99
Doesyour Canon EOS Rebel XS / Canon EOS 1000D suffer from either of thefollowing error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which theLCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. Themessage, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears onthe camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from theactual language setting.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems.
To download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
__________________________
Follow this link to download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download a pdf version of the firmware installation instruction guide.
Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
on Apr 15, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Tip
Canon Rebel XS Firmware Update WIN Models: Canon EOS Rebel XS / Canon EOS 1000D...
Does your Canon EOS Rebel XS / Canon EOS 1000D suffer from either of the following error messages that prevent it from normal operation?
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
To download the Windows version of the Canon EOS Rebel XS / Canon EOS 1000D firmware upgrade, click here.
I hope that helps.
Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Canon EOS Rebel GII With 35-80 Lens 35mm Film Camera shutter
In manual mode you should be able to change the shutter speed simply by turning the main dial (the thumbwheel located near the shutter release button).
Jun 28, 2012 | Canon EOS Rebel G-II 35mm SLR Camera
Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel 2000 EOS pictures are cut off by 1/3
shutter problem, cut off is part not exposed,replace the shutterunit.
Mar 07, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
On/off switch
The Dial on the top, there is a red icon, it is the OFF button, any other button is swithched ON. Altough it doesn't matter at all because the only way the camera is ON is whenever you are flashing or shooting, or presing the shutter button halfway.
Jun 24, 2009 | Canon EOS Rebel X 35mm SLR Camera
View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
May 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Shutter don't stop halfway
Yes, there is a small 2-stage micro switch that needs to be replaced. 1st stage is permanently pressed and not switching/returning back due to so many time it's been pressed.
It just time. Switch is right under top cover.
Apr 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
"BUSY" Problem
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
I hope that helps.
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
