Question about ASUS X83Vm-X1 Notebook
I have an asus x83v laptop, the hard drive went out, so i bought a 320 gb 7200, to replcae the old 250gb 5500, once i had the OS installed and all drivers it still thinks i have the old 250gb HD installed. i tried to update the driver but it says it's already up to date... any ideas?
    Guru:
  • 632 Answers
It shouldn't detect an hard-drive if its not there
If driver is still appearing click property's for that driver and click Uninstall Drivers. And it will fully remove them..
Where does it display you still have the hard-drive installed If you have replaced the hard-drive it shouldn't detect something that is not there, Although drivers may still appear on Old hard-drive files but when you install new hard-drive it will not have the Same drivers as it's new files, Although If hard-drive is same make it will install the drivers needed.
If you notice drivers that are for things you don't have you can un-install them but it may be best to leave them they will cause no problem so long as your laptop is functioning properly then there is nothing to worry about or change.
Posted on Aug 05, 2010
Log in to your laptop as the administrator, it should install automatically (Windows will recognize it).
Oct 23, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple tech 320 gb not spinning
Try a new usb cable or a different usb enclosure.
Also try and remove the drive from it's enclosure and connect direct to a sata port on a desktop pc.
Aug 23, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Jan 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
My iomega external hard drive (250GB) is not being detected by my laptop. I tried another laptop and another wire to connect it with the laptop but it didn't work. The light is on and I can hear voice when...
Most hard drives have two parts that you can replace one is the circuit board that controls the read/write head sometimes if you replace this with the exact board with the correct firmware (a few star drive screws) then it might bring the HDD to life.
The sad news is that if the mechanical part of the HDD has failed then it cost you £100's of pounds to recover the data from specialist companies.
Do not despair buy a new one of at least 250GB and you could try the old fridge trick with a zip lock bag overnight I have use this once to get the drive to work for a short time at least then using Windows Commander set it to copy all the folders to the new drive I have recovered about 70% of data from a failed drive this way.
Jan 19, 2010 | Iomega Silver Series 320GB 3.5 External -...
Gateway m-1625 laptop hard drive replacement
did you create a boot partition and format NTFS?
Nov 06, 2009 | Gateway M-1625 Notebook
Reformatted my external hard drive on accident
If formatting is not working, means there is some problem in the data segments of the disk.
thanks,
saumya.
Aug 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Gets stuck on the "asus" screen when i trun my laptop on.
Could be that the hard drive is not making a good connection. Turn the laptop upside down. Find the "latch" where the hard drive is "housed" and remove the drive... Then carefully and firmly replace it and make sure it makes good contact. Then try again to boot the laptop. If it still does not start up TAKE IT BACK to where you bought it from and let them sort it out 'cause it is supposed to be under warranty for at least 1 year
Aug 03, 2009 | ASUS Eee 4G Notebook
I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
Dec 31, 2008 | ASUS M2N-E Motherboard
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
How much big HDD can i connect to my ASUS-CUBX-L motherboard?
The size of the drive that will be detected can vary on a number of things: bios version, and OS.
They will both "physically" work, but the full capacity may not be "seen".
The 160 should work fine, but the 320 may only "show" as a 250 or 300.
My best advice is to flash the bios to the latest, and start with the 160. Install your OS, and connect the 320 as a slave after the OS install, and check its properties.
Jan 08, 2008 | ASUS Intel 440BX Chipset CUBX-L...
ASUS X83Vm-X1 Notebook Logo
479 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
