Question about Canon imageCLASS MF4370 Black and White Copier
I need updated drivers for my MF4370 - Canon imageCLASS MF4370 Black and White Copier
  • 1,219 Answers
Try on canon official software site, link: http://software.canon-europe.com/
Posted on Aug 06, 2010
Can canon mf4370 fax on dsl line
Fax machine operation can be interrupted by DSL lines, however, because the DSL signal is also transmitted through phone wiring. This can result in a loss of data in the fax if steps are not taken to prevent it. Fortunately, this is not a difficult thing to fix.
Items you will need
  • DSL filter
Step 1
Unplug the fax machine from the phone jack.
Step 2
Plug your DSL filter into the phone jack. DSL filters are specifically designed to eliminate interference from the DSL line on your phone line.
Step 3
Plug the fax machine into the phone line jack on the DSL filter. You can now use your fax machine and DSL line at the same time without risk of data loss or interference.
Feb 05, 2013 | Canon ImageCLASS MF4370dn Laser All-in-One...
Update drivers for my tavelmate 2300
Good Day,
To update your Travelmate 2300, just go tho this site to download and update your drivers as needed. Just be sure to check your current drivers version, you only need to update old driver versions. Just click on the links provided on that link for the drivers you need to update.
http://support.acer-euro.com/drivers/notebook/tm_2300.html
Hope this helps you. Thank you for using Fixya.
Jul 12, 2011 | Acer Computers & Internet
System Error E000.What does this mean?
It mean something wrong with your fixing unit.or heater not working.remove fixing unit and check all connection contact.try to replace heater or fixing unit
Jan 10, 2011 | Canon imageCLASS MF4370 Black and White...
I cannot scan from the network with my canon MF4370 scanner
This AIO, is a little er, a lot to be desired.
This is what I've found, and its only within my knowledge, which is of little, but, at YOUR OWN RISK...
The first problem is this unit requires a "Command to scan" that has to be generated from a 3rd party software that can "Acquire" a TWAIN image.
The second problem is that the scanner portion of this unit is not a windows recognized device.
So you have to make it appear to be a somewhat of a Virtual device, which may not be accessible to ALL applications. I will address this issue first....
On the driver disk that came with this unit is a program called:
Color Network Scangear Ver***.msi
This is my path which may differ from yours, you will have to "Explore" for it:
D:/Color_Network_ScanGear/driver/Color Network Scangear Ver***.msi
Install it, then "Discover" for the device, select it, and "Exit" out of this program.
The scanner will now be available to SOME applications.
Now for the next part, the 3rd party software.
On the disk there is also a program called:
PMsetup.exe
D:/PRESTOPM/PMsetup.exe
This program will work, but I don't like it.
I use Paintshop Pro 7 because it gives you a choice between the feeder or the platen glass to scan from and I have yet to find this feature in the Presto PageManager.
Remember, you have to have a software program that can send the command to "Acquire" a TWAIN image to the MF4370dn
If you made it this far, CONGRATS.
This is the process to scan on the network:
On the MF4370dn: (I now know what "MF" stands for.)
1. Wake it up if it is asleep. (Press Energy Saver" button)
2.Press the "SCAN" button twice to read "NETWORK SCANNING" on the display.
Load your document, remember depending on which place is active, either feeder or platen is the place you must load it.
Walk the 2 miles back to your PC.
3. In the 3rd party software, use the "Acquire" function, and the scan should load in to your software.
You may have to select the "Source" to "Acquire" from, chose the MF4370dn, it may be the only source to chose from.
Good Luck
What I want to know is: How to view the faxes in it's memory on the PC without having to print every single one of them. I get alot of Junk faxes which I dont want to waste the time and money to print them.
Dec 27, 2010 | Canon imageCLASS MF4370 Black and White...
Continuely jams and a redish black paper keeps comming out but it doesnt appear to be paper
these looks like fixing troubles to me.
You need to check fixing film, pressure roller, press. roller cleaner and bushings.
Call service, but keep in mind that these is too old model for any repair, I changed all these models with digital multifunction machines ie Canon MF4370 or iR1020.
Hope that helps!
Aug 09, 2010 | Canon PC1061 Copier
How do i get my canon image class mf4370 to print using windows7
Hi you need to check the drivers CD to see if it is compatible with windows 7 if it does, you only need to install it.
Aug 03, 2010 | Canon imageCLASS MF4370 Black and White...
How do I scan to my computer using the Cannon Imageclass MF4370 without getting up each time and pressing the scan button on the printer?
Sorry, you must get up each time and press scan button!
...or you can tell the copier under user mode - machine sett. - that you want scan as first function. That the machine will allways on scaner function. But when you want to copy or fax you will need to get up and transfer to wanted function, but scaner will be allways on :-)
Jun 26, 2010 | Canon imageCLASS MF4370 Black and White...
I installed xp on my hp a6683w and it does not have the driver for the network card. i cannot get it from hp because it was a vista machine. where can i get the driver
Most HP and Compaq computers come with full versions of Microsoft Windows preinstalled. Microsoft has an extensive library of software, drivers, and updates available for free download. HP and many of its partners work with Microsoft to provide drivers through Windows Update. Use the following steps to download drivers, software, and updates by using Windows Update:
  1. Connect to the Internet and see http://www.update.microsoft.com (in English).
  2. Follow the directions in the Windows Update page to set up Windows Update and install the software updates.
  3. Be aware of the following tips when using Windows Updates:
    • Install all critical updates first to help keep your Internet connection secure.
    • If you are looking for drivers, they can be found as optional updates from the list of available updates.
    • Due to file sizes, number of updates, and download time, use Windows Update when the computer is not being used for other activities.
For more detailed information about using Windows Update to install drivers and get updates for Windows software, see the HP Support document Updating Drivers and Software with Windows Update .
NOTE: Another great way to quickly get updated drivers from Microsoft is to open Device Manager, right-click the name of the device, and select Update Driver Software . Updating a driver from Device Manager c01162470.gif
Sep 25, 2009 | Computers & Internet
Canon MF4370 Paper jam
Ok fine and it is simple: trying blowing using portable blower concentrate in the area of paper parth.If this does not solve your problem attempt to remove all covers and ensure that all shutters of the paper sensors are working ok and in place.(paper parth areas)
Jul 27, 2009 | Canon imageCLASS MF4370 Black and White...
Canon imageCLASS MF4370 Black and White Copier Logo
180 people viewed this question
old marine
old marine
