HP Photosmart C4210 All-in-one I can't install color cartridge won't snap into place
    Genius:
  • 3,587 Answers
Check the underside of the print cartridge and the tray for any obstructions..tape, paper, etc..
Posted on Apr 26, 2008
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Cannot get the black ink to snap in place.
Make sure the printer is plugged in and turned on...the ink cartridge carrier won't be in the right place if the printer is off.
Jul 22, 2011 | HP PhotoSmart C4180 All-in-One Color...
How do i replace a colored and blank ink cartridge in my hp photosmart 8150?
The Open the front access door and the Carriage ( which holds the cartridges should move in center )
Push down the Cartridge ( which is in the cartridge slot ) and pull it out.
To install a new cartridge, Slide the cartridge from downwards and push up and it should get snapped.
Regards,
Ron
Feb 15, 2011 | HP Photosmart 8150 InkJet Printer
It says cartridge missing or not detected. its been cleaned as per hp website and the printer was also reset and it didnt help.
Hi
replace cartridge that gives you that error
wih a new one or refill an old obe if you have any
that work with with this method
Pls vote us to keep us alive
Nov 20, 2010 | HP Photosmart C4210
My color cartridge was low and I refilled it. Now my printer is
The electronics on your cartridge are bad and you need to buy either an HP original or a new refill to fix the problem. I recommend Cartridge World for refills because they test for electrical problems before they refill cartridges. If you do not have one of these stores in your area, Office Depot refills are the next best thing.
Jan 15, 2010 | HP PhotoSmart 1115 InkJet Printer
How do you install the ink cartridges?
With the printer on, pull down the cartridge door (the front section above the paper tray). This puts the carriage on the right hand side. Remove the tape from the new cartridge without touching the copper area. With the HP logo up, push the cartridge slightly down and forward until it snaps in. The color cartridge goes in the left slot and the black goes on the right. Push firmly to ensure the cartridge is fully in place. Close the cover and press OK in response to the onscreen prompts. (Confirm installation and then align the cartridge.) If the test page come out correctly press OK at the status page (in the LCD menus).
Oct 05, 2009 | HP PhotoSmart C4385 All-in-One Printer
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
How do I install ink cartridge into HP Photosmart Model C4280 all in one printer. I purchased the black and colored cartridges but can't seem to find any info on how to install.
Step seven: Install the print cartridges
NOTE: The product must be on before you can insert the print cartridges.
  1. Open the print cartridge door. Figure 7: Opening the print cartridge door c00880893.jpg
  2. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges. Figure 8: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot . Figure 9: Inserting the print cartridges c00880895.jpgc00880896.jpg
  6. Push the cartridge firmly into the slot until it snaps into place.
  7. Close the print cartridge door.
Aug 17, 2008 | Office Equipment & Supplies
Changing printer cartridges for HP Photosmart C4250 All-in- one
Pictures and Step-by-step here
  2. Remove the old cartridges, they will move into a position you can reach automatically.
  3. Make sure the print carriage moves to the right. If it does not move to the right, turn the device off, then turn it back on again.
  4. Open the packaging and remove the tape from both cartridges.
  5. Hold the cartridges with the HP logo on top.
  6. Insert tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot .
  7. Push the cartridge firmly into the slot until it snaps into place.
  8. Close the print cartridge door.
Hope this helps.
Jul 30, 2008 | HP Office Equipment & Supplies
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
97 people viewed this question
jasbo
jasbo
