Question about IBM ThinkPad X31 2672 Notebook
I have an IBM X31 Thinkpad It powers up and the fan runs but the screen will not operate and I cannot seem to get it to power up.As Suggested "I also examine the keys on the keyboard. one should look like a small monitor. generally you tap that key and the function key at the same time to toggle from external to internal monitor. try that first".I did that and nothing.
  • 734 Answers
Greetings,
I'm a laptop repair specialist, full time.
You've done the one action that definitively rules out a problem with the LCD panel and the Screen Inverter. Your problem is definitely hardware and not software.
The next least expensive hope of a resorative measure is to remove the RAM modules (sticks) and in some cases, only one of them may have failed. The modules are usually located underneath a small panel with screws on the bottom of the laptop and easy to remove. If you google "How to replace RAM for IBM X31" you'll likely find a quick easy guide online. The idea is to remove both (if there are 2) and replace one at a time. You have to remove the battery each time you switch one. Try both, one at a time, in each bay they clip into.
If you get the same result as your post with no improvement, then at the very least your video chip on the motherboard has failed. At this point you're going to need to have it diagnosed by a local laptop specialist or sent out to any one of several good motherboard repair companies on eBay. At eBay you would type "Laptop Motherboard Repair" in the search window and make contact with the vendors.
You're looking at $100 minimum to as much as $200 for this repair.
Lastly, please remember, "Don't shoot the messenger"! I wish I could have provided you with better news.
Best Wishes
Posted on Aug 05, 2010
Testimonial: "Thanks a lot, I will try what you said and see what happens. Mahalo!"
I have an IBM X31 Thinkpad It powers up and the fan runs but the screen will not operate and I cannot seem to get it to power up.Is there anything I can do myself before I have to scrap it or take it to...
there should be a fitting on that for an external monitor. hook it up to it to see if it works on that. also examine the keys on the keyboard. one should look like a small monitor. generally you tap that key and the function key at the same time to toggle from external to internal monitor. try that first. i wouldn't suggest throwing it out at all. if this is not a solution. post that someone if not myself will offer more advice
Nov 22, 2009 | IBM ThinkPad X31 2672 Notebook
IBM x31 thinkpad power off when in battery mode, when i shift to safe mode, it works fine the same thing when using the ac adaptor power directly.
Position your cursor on your screen and right click properties. Select screen saver and and at the bottom your will see power. Click on that and select when you you want your computer to power off on battery or AC power. You will have the option to select "never" on both.
Oct 07, 2009 | IBM ThinkPad X31 2672 Notebook
I would like instructions of how to change IBM X31 drive
This is the link to your laptop. Make sure to save yourself a copy for future reference. This should help you in what your looking for.
http://tim.id.au/laptops/thinkpad/X30-X31-X32.pdf
Oct 02, 2009 | IBM ThinkPad X31 Notebook
When i press the power button the fan starts up but nothing else happen. sometimes it turns on and when it does, i can use it normally for days.
seems like you have hard disk issue.
I would suggest that the next time you computer power up fully you backu up everything that is important to you.
you will need to take your computer to service so they will check your hard disk.
Sep 19, 2009 | IBM ThinkPad X31 Notebook
Ibm x31 password problem
Visit: http://www.ja.axxs.net/unlock/
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
  1. Power off the computer
  2. Remove the DIMM cover on the bottom side of the computer.
  3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
  4. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
  5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
  1. Power on the computer by pressing and holding F1.
  2. Enter the supervisor password. The Easy-Setup menu appears.
  3. Click on the Password icon.
  4. Click on the Power on icon.
  5. Enter the supervisor password and press the Space bar.
  6. Press Enter twice.
  7. Click on Exit; then click on Restart.
Jun 19, 2009 | IBM ThinkPad X31 2672 Notebook
My laptop ( IBM thinkpad x31) won't turn on
GO 2 CONTROLL PANNEL .DEVICE MANERGER .MICE AND OTHER POINTING DEVICES ,RGT CLICK PROPERTIES CHECK C IF THE DRIVERS WORKING ? HAVE FUN !!!!!!!!!!!!
Feb 20, 2009 | IBM ThinkPad X31 2672 Notebook
Thinkpad x31 wont turn on
plz try by resiting the ram, take out the battery and try to boot in.
Jan 17, 2009 | IBM ThinkPad X31 2672 Notebook
IBM thinkpad x31 w/ultrabay 2000 blu-ray drive question
If the bay is a DVD drive Blue Ray will work as long as you have a newer DVD decoding software. There are some decoders or codecs at IBM's support site, such as WinVid. If the codecs at IBM do not work with Blue Ray, then try download.com and search for DVD playing software.
Aug 04, 2008 | IBM ThinkPad X31 2672 Notebook
Power up on ibm x31
You will get a better response if you pay for the expertise we have to offer!
Feb 26, 2008 | IBM ThinkPad X31 Notebook
IBM ThinkPad X31 2672 Notebook Logo
293 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
