Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
I have an RP2100 Digital (PR185) with a faulty control circuit board 601553. can I replace it with a 601720 board? if so do I need to install updated sensors?
2 Suggested Answers
  • 368 Answers
SOURCE: Rp2100 main board has a
The new board may have the actuator relays and connectors on the main board. If so plug the wires in. If that is not the solution then you can call the Raypak technical support line and they may be able to direct you. Good luck.
Posted on Aug 15, 2011
I need to now how clen a filter on my rp2100 digital
rp2100 is a pool heater by raypak it has no filter. you need to clean the filter whatever type it may be. sand/de filters can be taken apart and the medium takin out and replaced, while cartridge can be taken out and sprayed with a hose and put back.
Sep 28, 2015 | Pool & Spa
Rp2100 main board has a piggyback circuit board attached to it with 2 relays controlling or wired to 2 jandy actuator valves. I upgraded heater to a new raypak heater & have no clue how to rewire with...
Aug 11, 2011 | Raypak RP2100 Heater PC Board Control IID...
AEG OKO LAVAMAT 86820 Update .Its dead.How can i fix it, but first, open the door without being pluged ?
Hi.
First you need to do an emergency emptying by accessing the filter.
Follow page 34 and 32 in this manual.
If you repute the solution helpful, then please do not forget to accept the solution.
Thanks.
Ginko.
Sep 13, 2010 | AEG Washing Machines
I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have power to the unit. Thats checked. When
You will need to replace the board before you can start. If that dosen't fix it, it will give you a reading as to what is wrong. PS make sure the power switch is on, most were on the front but some were about half way down the right side of the unit. They moved it to the face of the unit because it was too easy to overlook on the side.
Sep 30, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How to reset a RP2100 pool heater with original pc board
up and down button and mode or enter at same time for 7 seconds
Sep 08, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Bad LCD = Bad PC Board unfortunately...
check grounds to board also check transformer for voltage look for blown fuses
Jun 22, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
131 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
