Question about Kodak Easyshare C813 Digital Camera
How to solve lense error #126,1,0,-11 - Kodak Easyshare C813 Digital Camera
    Sergeant:
  • 420 Answers
Try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Posted on Sep 11, 2010
I HAVE A SONY DIGITAL CAMERA DSC T-20 AND HAVING AN ERROR MESSAGE E:61:10 PLEASE SEND ME HOW I CAN SOLVE THIS PROB LEM
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
I hope it will be Helpful for you.
Thanks and keep Using FixYa
Mar 16, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
F error code
Check the contacts on the camera and the lense.
This error means there is a communication error with the lense or it thinks that the lense is stopped down. Since its a G lense it cant be stopped down manually its gotta be some sort of communication issue. The electrical contact pins are springy and stick so they don't fully extend sometimes. This will improve with wear as the plastic channel is a bit too small and is holding the pin in the retracted position - repeated use will get the channel to get larger. I fixed mine by working the pins in and out manually until they all reliably sprung into position. Removing the lens a few times and fiddling with the contacts seems to have solved the problem..You can check by moving the lens when it is mounted to see if you can replicate the error.
Dec 21, 2009 | Nikon D90 Digital Camera with 18-105mm...
S 10 lense error
try these:-
  • shake it.
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 17, 2009 | Nikon COOLPIX L10 Digital Camera
Its says error 99? means? can somebody help me? saying shooting not posiblle , needs to turn off/ then turn on.. and i tried so many times but it never helps. please help me .
hi
this error 99 is generally occured when the lense is not recognized
this has been a common problem reported
we'll clear the contacts and connect the lense
try turning the Image Stabilization off and this could solve your problem temporarily
hope this helps
cheers
pls reate the solution if this helped any
Jun 28, 2009 | Tamron 28-200mm F3.8-5.6 for EOS
Error message in D 90 camera
I had the same problem (same kit). I even exchanged the kit for a new one, and had the same issue. I'm convinced it's the connection between the camera and the lense - when I wiggled the lense, it would sometimes return to normal. I considered cleaning the contact points, but then the problem went away. I've been shooting hundreds of times, without it happening once.
May 01, 2009 | Nikon D90 Digital Camera with 18-105mm...
Zoom error
you may be true that sand must be creating this problem, as this happens very often. the sand enters into the lense assembly, creating friction in the movement. if this has happened total dismantelling and cleaning of the lense assembly will solve the problem, but that has to be done by an expert at the repair shop.
Aug 17, 2008 | Olympus Camedia C-350 Digital Camera
When I turn on my Camera, the screen turns blue and say Zoom Error in red writting, and it wont turn on, and the shutter will not shut!
This happens du to friction in the movement of the lense assembly. Did you happen to drop it in sand or on hard surface. If the camera if exposed to sand, just the cleaning of the lense assembly,( gears and the barrels) will solve the problem. But, if any damage is there then the complete lense unit needs replacement.
Jul 17, 2008 | Olympus Cameras
Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
Mar 27, 2008 | Nikon COOLPIX L3 Digital Camera
Lense error, restart camera
probebly you lost your motor which drive your lence in camera
dont do anything because this problem is not the one which we can solve by our selve
so kindly go to any service station near you
Mar 26, 2008 | Canon PowerShot A560 Digital Camera
Lense error
i recieve a lense error on my camera.i notest a little crack on the lense and the camera turns on and then right off. can you help me. thank you
Dec 23, 2007 | Casio Exilim EX-Z50 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
122 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
