Question about Acer TravelMate 3270-6569 Notebook
My laptop can on but sometime when i turn on the machine it goes dark and very dim can see the images but very hard..whats the problem graphic card?,or the lcd screen cable or the inverter or the screen has to be replace or the back light?i have not tried connecting to external monitor cause i don have any cable for tat..sometimes when i try to press the cover lid can sometimes cannot.tried ask shops for reason they say maybe screen ,inverter or the graphics..i confused really which is the real cause for tat
  • nana_airul Aug 06, 2010
    micROSOFT WINDOWS VISTA BUSINESS NO SETTING IS ALLRIGHT THE PROBLEM IS THE SCREEN OR THE INVERTER OR THE GRAPHIC OR THE BACKLIGHT PROBLEM
    Champion:
  • 219 Answers
What operating system are you using? On laptops there are settings for when your using battery power that dims the screen to conserve battery power. This could be the problem in your case.
Posted on Aug 06, 2010
  • swufabuda
    swufabuda Aug 06, 2010
    Well then I don't think it's the graphics card.
Sony Vaio E Series VPCEH37FX screen goes dark, but fine otherwise
If you can see faint dim images on the screen, then your back light or power inverter has failed. They are not adjustable or repairable and must be replaced. If you can't see anything on the screen, the LCD has failed and must be replaced. Sometimes it's hard to see the dim images so use a flashlight to help determine if there is any image on the lcd.
Oct 27, 2013 | Sony VAIO Computers & Internet
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
VERY Dim screen after a drop
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
My notebook screen 3000 n100 goes dark after few second
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 15, 2009 | Lenovo 3000 N100 0689 Notebook
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 11, 2009 | Compaq Presario Notebook
Blank display
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jun 23, 2009 | Toshiba Satellite M35X-S161 Notebook
Screen goes blank while typing
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5315 Notebook
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Flick Screen
Hi alex , first try to get the latest update for the laptop graphics adapter (start > settings > system tab > settings > than look at what graphics card is installed (display / graphics ) write down the type and brand and search via google for signed drivers (latest version) for your operating system and check if the display is set to the correct refreshrate (should be 60hz ) , some displays however need tot be set to 75hz. if this does not solve the flickering , search for a update of the auto dim feature. if this doesn't help either i guess it may well be a lcd problem with the signal cable it can be fixed but if there is waranty on it better bring it to your supplier and ask them to fix it instead of trying to fix it your self ..
Apr 27, 2008 | Acer Aspire 3003WLCi Notebook
Acer TravelMate 3270-6569 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
