Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Problem with RCA D52W20 HDTV rear projection television
It is kind of difficult for me to explain what is happening, but I will try my best. I bought the television in July of 2005 and had no problems up until a few months ago. A few months ago, my television after being turned on was showing a very blurry picture. Also, the screen size I keep stopped being locked in and it would change until I redid it. The blurriness would go away after time, and within a half hour or so the picture on the television would be fine again. That went on for a few weeks then went away. It has been fine since then for the past two months or so. A week ago it started doing the same thing. When I would turn on the television it would be very blurry and it would take a little while to lose the blurryness and actually have a viewable picture. However, this time, after the blurryness goes away, the screen flickers and I hear a crackling type sound. Everytime I turn on the television it gets worse and does it for longer periods of time. I checked the aux channels and it does the same thing when I use a DVD player, or XBox, or anything else on the television. Today the crackling anf flickering has not stopped at all. Any help would be greatly appreciated. Am I out of a big screen television or is there something I can do to fix it?
  • 1 more comment
  • DBendau May 02, 2008
    How is a flyback installed? I am not very good with electronics, and don't have much in the way of equipment. Before I buy the part I want to know that I can install it. Thanks for any help.
  • Anonymous Nov 25, 2008
    TV flickers when I turn it on.
  • tboz70 Mar 05, 2009
    I ordered the flyback, but I have no tech support. Can you tell me how to get these wires disconnected? There's a black wire and a red wire coming from the flyback, which do not want to come loose. I traced the black wire to the front of the tv, and I can disconnect it there. The red wire however, cannot be disconnected easily at the flyback nor at the front of the TV.
  • RCA Master
  • 8,617 Answers
Go to this site you need a flyback its the only onethey sell for an RCA number 259296 cost less than 50.00 and they provide free tech support so you can do the repair yourself which takes about a half hour. a repair shop will charge abut 400 to replace the flyback. heres the link
http://servicemanuals.vstore.ca/
Posted on Apr 27, 2008
Connecting toshiba satalit to rca d52w20 tv
use the front s-video connection, there will be no sound unless you get a 1/8" pin (mini headphone) to male rca cord
Feb 25, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
I HAVE A D52W20 RCA 52" REAR PROJECTION THE
Bad connections on the vertical output ic, also check connections in tuner/if module, Real common with RCA to look like vertical trouble.
Nov 06, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I own a rca d52w20 television, (pretty old, I know) and the red isnt really red, and the green is kind of brownish. is it worth fixing? i just bought it for $100 dollars. thanks
i would suspect the glycol has gotten dirty. as the serts age there is a repair that can fix this .....but no i am sorry to say. most shops charge a bit for what is called a "gycol change" this is labor intensive. my shop gennerally charged around 100 per tube and 20 for the fuid. 3 tubes= around 350.
Mar 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will a hd dvr work wirh rca hdtv projection tv
yes a hd dvr will work with any hdtv just know that you will need a hdmi cable for the best available picture, and also projection hdtvs are not as clear as plasma or lcd
Mar 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20
Check 3 capacitors green and gold 2200uf 16v two 229uf 35v cp150 location if 16v cap the other two caps next to it ,other wise replace the deflection board.
Sep 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color
You may need to replace the convergence IC's on your TV. I suggest you get this done by a competent serviceman, as it is difficult if yu are not experienced in this kinda stuff...
May 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
258762R PARTSTORE REPLACEMENT CIRCUIT DIFFERENT FROM ORIGINAL
contact the store and explain that the rebuilt board is not the same have your model and chassis numbers on hand
Apr 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Silver Box
Silver Box? please explain your problem...for d52w20
Mar 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20?
ok ...first question ... what happens when u push menu?...do you get any osd...on screen display...menues volume.. channel number. HOw bout any sounds... the light comes on and the stays on..?
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
351 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
