HI im trying to connect my ps3 to my samsung lcd le26s8 40 inch tv but i have connected all my hdmi cables and power cables and it seems to be really difficult when normally it really isnt please get bak to me asap thank you
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
  • 92 Answers
SOURCE: LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Posted on Mar 28, 2009
  • 105 Answers
SOURCE: JVC 40 inch LCD digital inputs (1 and 2) no longer
This TV has a sensor that deactivates the inputs when light is sensed. perform this procedure to correct it:
1. press "Sleep" button on the remote
2. while "Sleep timer 0" is showing, simultanuously press "display" and "video" button on the remote
3. you should be in the Service menu of the TV....if not you should do the steps again
4. select "self check" from the displayed options.
5. when the "self check" menu is displayed, Power off the TV.
6. unplug and replug the TV.
7. Check the digital input.
if the input never worked for you, it is possible that you have the DVD/Bluray/whatever set up incorrectly. I don't think this TV accepts 1080P resolution so make sure it is set to 1080i or lower
Posted on Jun 23, 2009
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
Im trying to connect my playstation 3 to my 42 inch LG lcd tv
When connecting the ps3 to a nice TV like that, you want to use an HDMI cable. You can use the stock red white and yellow plugs to connect to the back of the TV, however you will not get the full HD experience like with the HDMI cable.
Dec 25, 2010 | LG Televison & Video
My samsung tv wont connect to my ps3 through the hdmi cable, the tv works if i connect my laptop or anything else to it. iv tried my ps3 on my lg an it work just fine just cant get it to work on my samsung...
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
Dec 23, 2010 | Samsung LN52A650A LCD TV
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Connection error from ps3 to tv.
When you hit the power button from the console, hod it until it beeps at you twice and it will reset the video settings. I read this on a post from gamespot. I hope it works.
Jul 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Feb 26, 2009 | Samsung Televison & Video
Sony ps3 an samsung tv
Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
