Question about Vacuums
Car starts fine! But will not idle and remain on.
  • 4,102 Answers
Hi, This could be several problems but i'll need to know what make and model and if it is diesel or petrol!! (If petrol is it injection or carb) Once i have this information i will be able to assist you further!
Your lucky that i'm a mechanic because this site is designed for electrical appliances e.g. TV's, PC's and Printers etc
I can help will need more information first!!
Speak Soon!!
Posted on Apr 26, 2008
Installed aftermarket stereo and now car want start but everything else works
Switch the wiring harness for the cd player back. t probably disabeled the ignition systime in the car.
May 01, 2014 | Brembo 2007 Dodge Charger - SXT, RWD -...
Toyota rav 4 2008 idle problem
take it to fas lube under car to get it fixed at the cheapest rate
Mar 23, 2014 | Toyota rav 4 tube, airfor idle-up. vacuum...
Hi, my Dyson DC16 works fine but after removing from charge base following recharge the red and green lights remain lit and the unit will not operate until i remove the battery and reconnect to vacuum,this...
If it is within the warranty period get Dyson to replace it. If not, live with it until it fails completely, then buy a Hoover. Your computer board is starting to fail. That's not repairable.
Aug 06, 2017 | Dyson DC16 Root 6 Bagless Handheld...
1994 GMC PICKUP 1500 4+4 ,HAVE A PROBLEM WITH IT STARTING IN THE MORNING (RUNS ROUGH) DID REPLACE FUEL INJECTORS BUT DID NOT HELP ,ANY IDEAS?
Do some research with Google and First would be IAC or Idle air control which could along with some other things cause this problem.
Dec 18, 2012 | GMC 1994 1500 PICKUP Front Knee, Driver...
Change motor brushes on Fein vacuum
If the vaccuum was used with large amount of fine dust , most times the filters are largely shut beaten ,beware also of the electric field look its color to get a indication of the expectation of the remaining running time of the motor. 80% chance by use of fine dust the motor can better be replaced instead of replace brushes because the brushes are in a short time again shorted because of 1 collector in the armature , or get an equivalent motor if you can get FIXAPART motor or a original replacement if the remainder is still in reasonable condition.
Some brands of vaccuums uses the same motor could be sometimes an option because of the price.
Sep 07, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
Spilled oil in boot of the car how do you get it out
put down cat litter or sawdust and sweep it out. repeat this until no more will absorb. then if it is carpeted use foaming spot cleaner and follow the directions. If not carpeted, use Dawn and warm water to remove remaining residue. ( this will work okay on carpet as well, if you have nothing else to use.) farmerbear at FixYa.com
Sep 30, 2010 | Vacuums
Oreck XL2 does not start.
There could be a problem with the cord. I suggest taking it to a local vacuum shop to have it inspected as that could be the problem
Apr 13, 2010 | Oreck XL2000 Bagged Upright Vacuum
Start button does not remain depressed when turned on.
Sounds like a defective switch that won't catch. Is it still under warranty? You could put something higher than, but roughly the same size as the button on it and duct tape it on until you get it replaced. If you're handy you could replace it with a toggle or rocker switch at about $2 but it's not as suave chic. If not it should be a fairly cheap repair at the dealer.
May 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Mcculloch chainsaw 2416
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
Aug 03, 2008 | McCulloch MC1275 Steam Vacuum
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
