Question about Cameras
My nikon coolpix s220 is showing a lense error. i'll turn it on and the lense will pop up and go back down like, five or six times, and then the screen will display a lense error. it sounds kind of like it's struggling to open, or at least working harder to open it that it usually does.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 05, 2010
  • ntraining Sep 19, 2010
    It is a Nikon. It belongs in the garbage. Place it there immediately. Get another brand of camera. Problem solved. Don't believe this? Check the web for the number of problems people are having with crappy little Nikon point and shoot digicams. They're not gonna stop selling **** until people stop buying ****, folks.
Looking for user manual for nikoncoolpixs220
You can download the S220 manual from
http://support.nikonusa.com/app/answers/detail/a_id/16312/kw/s220/r_id/116678
If you want other Nikon manuals, you'll find them at
http://support.nikontech.com/app/answers/detail/a_id/13948
Jun 15, 2011 | Nikon COOLPIX S220 Digital Camera
My nikon coolpix s220 have a lens error and when i turn it onthe lens goes in and out like its trying to focus and it makes a wierd noise. it also wont let me do anything it just pops up saying lens error
Try removing the battery/batteries and clean the contacts underneath. Also, clean the battery contacts and the charger, if so equipt. To do this, dampen a cotton swab with rubbing alcohol and rub the contacts. Blow into the compartment after to clear any residue.Thanks, Dana
Jan 03, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My Coolpix S220 (Nikon)'s lense is stuck. The lense itself is not straight and it won't turn on or off beause the lense will not go back in. I'm not sure how it happened because I didn't drop it or...
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for spares.
Oct 31, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I dropped my Nikon Coolpix S220 and my lens is stuck. When I turn it on it has "lens error". Can someone please help me?!
I do not know how many times I've seen this question, and knowing that I asked this question so many times in the previous years, I know the answer now.
The thing is the lens are gone, nothing can really cure it unless you spend up to hundreds repairing it. If you still have the warranty, you can send it up to the manufacturers, but other than that, it's either a new camera or spending more getting it repaired.
I bought two nikon cameras, my first one got a bit of sand in it, I only took it out once at the beach, and what do you know it says lens error the next day. GONE. my SECOND one fell from about 2 feet-3 feet also, the lens were pushed in and it made an EH EH EH sound, as for all lens errors do. It was GONE.
My advice is to save up for a new camera , and get a SONY or CANON, or one w/out lense.
Oct 10, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Lens error in nikon s220 digital camera.
Yes you right. After fall down the lens internal guide pin is damaged and thats why its happens. a912d76.jpg So visit your nearest service center for repair. Thanks.
Mar 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Can't transfer pictures to computer
Found solution thru a google search, unplugged the camera from the computer, turned the camera off, plugged it back in and then turned it back on, the camera icon finally showed up in the Nikon transfer program
Jan 28, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Cameras Logo
402 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
