Trying to install a windows xp boot cd on an asus desktop I keep trying to boot from the cd, but all i get is the same error message : disk boot failure, insert system disk and press enter. I've tried a different optical drive, and I still get the same message. I've changed the boot order in the bios........same thing. I've even tried a different boot cd, and still nothing. Any ideas ? Mind you, before this happened it was a bad virus on the system unit . It wouldn't even let me install a new anti-virus through usb or cd.
  • David Dahwud Hughes Aug 05, 2010
    With all that I've done you would think that, but i tried a new hard drive that I know is good and it does the same thing.
  • David Dahwud Hughes Aug 06, 2010
    Damn good advice ! Thank you for everything especially 4 tha ubcd link
  • 3,153 Answers
Ok that must have been a darned good virus
First off get yourself a copy of UBCD from here
http://www.ultimatebootcd.com/download.html
Burn it on a known good CLEAN computer
Now double check your optical drive cables and more important the JUMPERS. Set them al to CS (cable select) and do the same with your hard drives.
Make sure that there are no hard drives on the same cable as the optical drives !!!!
Disconnect any external drives !!!
Once you have done that then you need to ensure your BIOS is set to boot from CD first. It may be better if you set the rest of the boot options to CD for this exercise
You should also turn OFF "boot from other devices" if your bios has that option
If by any chance your comuter has a SATA card in it (not on the motherboard) then move that to another slot (trust me on this one)
You should now be able to boot from CD.
Boot from the CD you burned and use the disk utils on there to wipe your drive. YOu WILL LOOSE ALL DATA.
If you have more thanm one drive and the virus is as bad as you say then wipe any other drives as they may also be compromised.
Once you have done that then shut down and re-start the computer with the operating system cd in there.
Note here that pirate copies of operating sytems may not always boot correctly so it has to be a 100% legit copy.
You should now be able to boot from that and install as normal.
If the installation restarts then before it gets back up nip into the BIOS and reset your boot option to hard drive first and cd second and then any other options you may have.
Posted on Aug 06, 2010
    Genius:
  • 1,478 Answers
In this case with all you said you have done, i think the hard drive on your laptop as crashed, you will need to get another hard drive on the system. The best thing you can do in this case is to get a new hard drive.
Take care.
Posted on Aug 05, 2010
Dell Dimension 4550 BOOTMGR is missing error message
To repair missing orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
Jul 09, 2012 | Dell Dimension 4550 PC Desktop
WINDOWS ERROR MESSAGE
boot from the CD copy of your windows XP. enter in console session and manually replace the file. if the file is corrupted this should fix it
Feb 26, 2012 | Gateway GT5026E PC Desktop
I HAVE NO NEW XP WINDOWS RECOVERY CD FOR MY MEDION MIM2220 SO I CANT START WINDOWS , WHEN I TRY TO INSTALL FROM RESTART IT COME WITH THIS MESSAGE WHILE TRYING TO BOOT ( AN ERROR HAS BEEN ENCOUNTED THAT...
Do you have the original installation disk that came with the computer? You can try to boot from that CD and do a repair installation. The Cyclic Redundance Check (CRC) error refers to the media the computer is trying to access (either the CD or the hard drive). Try booting into Safe Mode (reboot and press F8 repeatedly until you get a boot menu). From Safe Mode run a checkdisk (chkdsk from command line) on the hard drive to find and repair any found disk issues.
May 25, 2011 | Medion (40010998)
ZT Group CISNET A7022 disk read error
how are you installing it ?? boot from cd ?? or from a image or ??/if its from the disc..and its blocking ..and do not continue to copy files..the problem is the disc...its damaged ...if you want a copy look for me on yahoo ...catalin_yo_vlad I will provide you a image copy ..with a serial no that will be rec as original ...ad up-datable to sp3
Aug 01, 2009 | ZT Group CISNET A7022 PC Desktop
Can not re-install XP. Get "Unmountable boot volume" error.
Usually it's because you're missing the SATA drivers.
Did you slipstream those in too?
Jun 15, 2009 | ASUS Eee PC 1000H Laptop
No harddrive detected, verifying dmi pool data, disk boot failure
Help on making a bootable XP install CD for including storage device drivers (such as SATA drivers that's not included in older XP CDs): http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
Follow my brief instructions to make an updated XP CD.
May 15, 2009 | Acer Veriton 7500G PC Desktop
Missing or corrupt hal.dll file, so can't boot the hard drive
Hey,
Please use the recovery discs or windows installation cd.
To either perform a full system restore with the recovery discs.
Or to perform a repair installation with the windows installation cd.
Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Thanks and good luck.
Ekse
May 03, 2009 | Dell Dimension 3100 PC Desktop
FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
I have experienced this problem as well, it is either the CD is scratch or the CD-rom lens needs cleaning, however it can read the content of the CD, I would susgest you try a another CD-rom , borrow it from a friend. It works for me.
Nov 06, 2008 | Dell OptiPlex GX150 SF PC Desktop
ACER DESKTOP COMPUTER
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
best regards wish u give me a good rate ^^
Aug 15, 2008 | Acer Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
