Question about Coleman Mach 15 Air Conditioner
I gewt no power to my compressorcoleman 15 model
I have a running fan, but no power to compressor,my thermo seems to be working corectely, and I need info on the relay in the box,as I,m gettig power to it, but it doesn't operate for power, and theother says NO??
  • 828 Answers
On these relays NO means Normally open when power is not supplied on the control voltage side. Most A/C system control voltage is supplied by a transformer, which supplies the thermostat, which in turn supplies the power to the relay when cooling is called for. If you do have, say 24 Volts present at the relay the normally open contact should close giving power to the compressor for cooling. If the NO contact is not closing you relay coil may be open. In this case replace the relay.
Posted on May 11, 2008
Why is my True THAC-48 unit is not cooling?
need more info. is the condensor fan running? if not thermostat problem.if it is , is the compressor running or just makes a one time click a few seconds after plugged in? (after unplugged five minutes)... if this is the case it probably needs a new start capacitor (170 uf)..if the compressor is running the larger tube going in the commpressor should be cool about 40-50 after a few minutes .. if not then it is low on refrigerant..R-134 after 1995. or R-12 for older models.. now you also have inside fans and thermo buttons that can not be working.
Nov 09, 2013 | True THAC-48 48in Horizontal Air Curtain...
My split ac`s compressor got overheated and stops working after 15 min but fan was running
this is because the compressor is thermoing out meaning it is getting to hot and the windings on the compressor are opening causing the compressor to go off, it is a safety for the compressor so it does not get ruined. have an ac company or someone who knows what they are doing come take a loo at it, it sound like bad start components to the compressor, also have then check the freon levels as well.
Oct 22, 2013 | Heating & Cooling
COMPRESSOR RUNS A LOT
Your model has a mechanical thermostat inside the control panel. I believe you have something else going on like a bad fan, start relay, capacitor. Something is causing the compressor to struggle to keep up and in turn causing the compressor to short cycle. If the thermostat has no control over run time then something like I explained is causing the problem. Here is a parts manual=> ED5VHEXVB04 Contact me if you would like my help, Thanks Sea Breeze
Feb 26, 2013 | Whirlpool Refrigerators
Lennox outside unit fan will not stay running unless i reset the red button
You should replaced the fan motor along with capicator
Jan 10, 2018 | Heating & Cooling
Outside fan doesn't run while compreesor is running and coils are hot
See if the fan is getting power if it is fan is bad if not check the connection to the thermal sensor on the compressor to See if it has come loose.
Aug 06, 2009 | Amana Heating & Cooling
Air conditioner problems
change the thermostat for a more user friendly one
Aug 06, 2009 | Heating & Cooling
Fan motors
Check that the fans are still working .Check that the thermo switch is working.Check that you have power to the thermo switch. and if not check relay/supply of power.Unsure with your model but the thermo switches are usualy screwed into the radiator but could be mounted on the engine.You can check your fans by running a piece of wire from the positive terminal of the battery to the positive side/wire of the fans.As long as the fans are earthed as well they should work and if not then the fans will need to be replaced.
Oct 10, 2008 | 1990 Nissan Maxima
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Coleman Mach 15 Air Conditioner Logo
76 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
