FixYa.com
Tags:
Intel SC5200 SSI EEB 3.0 Case
Alternative Power Supply for Intel SC5200 Base
By Hart - usenet poster
I need to upgrade the power supply of an SC5200 Base (450W) chassis,
the only Intel option is to buy the SC5200 HS Server Chassis (650W
2+1,Hot Swap,RPSU Ready) which is a bit expensive.  Is there any power
supplies out there that have the same dimensions of the standard 450W
PSU in the base chassis?  I'm sure there must some generic more
'economical' option out there ;)
antimatter.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
maartenw
maartenw - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On 19 Jul 2005 00:09:00 -0700, "antimatter"
Not generic, that's a specialized PSU that will cost quite a
bit more than anything standard.  Then again, when it claims
"450W", that's usually TRUE watts, not optimistic ratings of
momentary peak wattage like with a PC ATX supply- it's
form-factor is just too small to sustain 450W long term.  I
think they do come in smaller than 450W size though, but
you'll have to detmine for yourself if something in a 350W,
if available, will suffice for the system.
Also see this:
http://support.intel.com/suppo rt/motherboards/server/chassis /sc5200/s...
and this,
http://www.shop-intel.com/shop /category.asp?category_id=76
might be something useful here too (or maybe not, i don't
know),
http://www.centrix-intl.com/
http://froogle.google.com/froo gle?q=SC5200+power+supply&scor ing=p
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
Thanks, problem is I need more wattage ... chassis is driving a Dual
Zeon, 6 SCSI drives, 1 Seagate IDE drive, DAT tape drive, 1 cdrom
drive,  2 Fans system.  That according to my calculations is pushing
the 450W supply, I also get these 'unexpected' reboots ... I imagine it
is the PSU resetting when all the devices draw close to 100% power
simultanously ... a theory, not sure if it is the case but would like
to eliminate power issues;)
Solution #3
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
On 19 Jul 2005 02:18:04 -0700, "antimatter"
That sounds a little high, it's probably not using more than
350W, actually less than that but considering a margin...
How are you calculating this?
Under what scenarios (system load) is it rebooting?
I would expect that initial power-on is the peak load, while
drives are spinning up.  Then once you have it in a modern
OS, ACPI should be mostly idling the CPUs unless this box
has a pretty heavy load.
You need to collect some data.  Multimeter readings of
voltage levels in recreated scenarios, logs from operating
system, load-reduction from temporary removal (unplugging)
of parts.
If you're still considering what was happening with the PSU
that failed, it could've simply been that one specimen of
PSU, not indicative of anything else in particular.  Does
the failed unit have the serial or model numbers
corresponding to that Intel failed-diode document?
Can you Help with these PC Cases problems?
PC Cases
Occurrence of a number
The user will enter a number... Answer This...
PC Cases
283 ipc
what about 283 ipc Answer This...
PC Cases
ei 4419 laptop
how do I remove the keyboard Answer This...
PC Cases
cd drive
my cd drive or dvd drive... Answer This...
PC Cases
funnyscandl
how do I get rid of it Answer This...
Repair Service
Find PC Case Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
