Question about Sceptre Televison & Video
I have a sceptre x23 that i have had for almost 2 years. it is not used very much. when it is used there is an occasional black bar that will pop up on certain channels. it also turns off when using the remote and pressing different buttons other than the off button. the other day i turned it on for a minute...it started to get a little fuzzy, wud not power off with remote or button on tv, so i had to unplug it. it will not turn on now. it is getting power b/c red light is on, but actual tv will not power on to the blue light..no sound..no picture...nothing. any suggestions
Did you ever figure out how to fix this? My TV just did the same thing.
Posted on Oct 08, 2011
Have a Sceptre 32" TV that changes sources all by itself, how do I fix it?
Model Number?
It may have a setting to automatically switch to a new source. Check and see if that is off. Also, power down your other connected devices completely, as some will occasionally "ping" the TV to make it's still connected while in sleep/idle mode. The Nintendo Switch is especially bad at that.
Jun 18, 2017 | Sceptre Televison & Video
Codes for sceptre tv remote control
The remote for this TV works on Sony Universal remote codes.
See this user manual.
http://www.sceptre.com/pub/Manuals/LEDTV/E325BV-HDH-0229.pdf
So if you want to use the remote for other devices then best to visit this Sony website and find the codes for the devices you need. Select the Brand from the list and the code pops out on the side. It is not clear what you want to use the remote for.
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMVZ220
Sep 04, 2014 | Televison & Video
X32 sceptre ledtv goes black with sound
check power supply board, bad capactors, or replace board if cheap, check on ebay for a used one..
May 24, 2014 | Sceptre "32"" Class 720p 60 Hz Lcd Hdtv...
I have an Sceptre 37"
For most TVs in the market, you would use their DYNAMIC or VIVID mode for the best picture settings.
Sep 09, 2011 | Sceptre Televison & Video
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
No power.
My 3 year Sceptre 27" died. Local TV tech said it was the power module. Charged $25 for the diagnosis and wanted $190 to fix it. Took it home, popped the screws and the module almost fell out. It's a simple plug'n'play!!! Found a new module on eBay for $65 shipping included.
Dec 17, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre
It sound like either a power or power connectivity issue. I recommend that you first complete a hard reset on the tv (unplug all power to the unit and accessories for at least two hours, sometimes more. Then plug the unit and accessories back in. If that does not work then I recommend using one of our premium services or searching for a local repair service search button located on this page. Just type in your zip code.
Thanks,
CH
Jul 29, 2008 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Power problem
Check out ebay for the part.
Jun 03, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Televison & Video Logo
387 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
