Question about HP Officejet Pro L7680 All-In-One Printer
How to replace the roller on top of the printer?
  • 225 Answers
Usually cleaning the roller is enough to get it working again.
Posted on Aug 05, 2010
Printer feeds more than one sheet at a time
clean the rollers and replace the sep pad or sep roller which is the bottom roller, first one is pickup top one transfer bottom sep. or replace all
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 20, 2014 | Konica Minolta PagePro 1350W Laser Printer
How can I stop paper jams when using duplex printing?
1. Replace "Roller top out put bin" (RL1-0527-000CN)
2. Clean duplexer unit & chk the rollers in size change assembly(RM1-1318-000CN)
Apr 29, 2014 | HP LaserJet 1320tn Printer
  • Tray 1 Pickup Roller Replacement
  • Turn off the printer and unplug the unit. Remove the following doors: the DIMM cover, rear cover and top cover.
  • Open the door to the area housing the toner and remove the toner cartridge. Set it aside. Release the toner drive arm located at the right side of the toner door.
  • Locate and remove the screws at the front left and right corners on the top of the printer and the two screws at the right and left at the top of the back of the printer.
  • Locate the latch at the left side of the hinge for the toner door. Release this latch and then remove the door.
  • Pull out the old pickup roller and replace it with the new tray 1 pickup roller. Reassemble the printer.
  • Feb 21, 2011 | HP Office Equipment & Supplies
    Top paper feeder roller rotates but does not draw in the paper
    There is no replacement rollers available so, printer needs to be replaced.
    Apr 08, 2010 | HP OfficeJet 7310 All-In-One InkJet...
    No paper pickup, press enter
    Suspect worn and or dirty paper pickup roller. To check the roller simply open top cover and remove toner cartridge. Roller is D shaped and can easily be removed by gently pressing the two tabs outwards. This should pop out the roller from the holder. Clean roller and check for wear. If worn replace.
    Feb 23, 2010 | HP LaserJet 3055 All-In-One Printer
    Paper gets stuck, comes out only partially and crumbled
    It is a hardware problem. So you can check it from service center.
    Nov 04, 2009 | HP LaserJet 4 plus Printer
    HP 2600n Ironing transfer paper jammed around top roller
    It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
    Jun 05, 2009 | HP Color LaserJet 2600n Printer
    The printer wrinkles the paper
    look like you have a cracked fuser roller problem. To see it, visually observe the section where the paper exits from the printer. You will noticed a grey colored long roller riding on top of another long orange colored roller. Its usually the grey colored roller whereby certain section of the roller foil/film have been torn off and it need to be replaced.
    Best Rgds
    Mar 05, 2009 | HP LaserJet 1010 Printer
    HP Officejet Pro L7680 All-In-One Printer Logo
    87 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
