Question about Bosch Nexxt WTMC 6500 Gas Dryer
Want to set up for propane is the jet shipped with the machine
  • 347 Answers
No. not unless requested for propane when ordered .will have to be ordered seperate and installed by a certified technician
Posted on Aug 06, 2010
Maytag range Natural gas jets to Propane jets
it is a simple replacement but the problem is properly adjusting the air shrouds to get the right air/ gas mixture to burn correctly
lpg jets are available from a gas supply shop and because of the dangerous nature of gas , I would suggest that you have an accredited gas fitter do the conversion
Nov 25, 2015 | Maytag MGR8674AS
My motorcycle won't start no fuel to the motor of sets more then 10 day .why is it not getting fuel to the motor ?
pilot jets are plugged, carbs will need to be removed and jets cleaned floats could also be sticking ,not allowing fuel into the bowls cleaning carbs properly will fix it ...fuel leaves a residue that plugs jets when it evaporates
Sep 05, 2017 | 1992 Honda GL 1500 Aspencade Gold Wing
How do I convert my weber s-470 NG outdoor gas grill to liquid propane?
Hi You will half to replace the NG Jets to Propane ones. Go to your manufactures web site and search for jets for propane. Some manufactures don't make them. Good luck.
Jun 09, 2014 | Grilling
GE gas range on propane, using propane jets, the burner regulator knob has little effect on heat output. Is this a gas burner valve issue?
You also need to set the regulator to LP. The symptom described is an indication that the regulator is still set to natural gas. The manual should tell you how. As I remember, there is a cap on top of the regulator that is removed to allow access to a retainer that needs to be turned over so the "LP" is facing up. Check your manual or look it up online
Sep 18, 2012 | GE Profile JGSP44 Dual Fuel (Electric and...
How do you adjust the air to propane ratio?
You need to change the gas metering jets, there are different one for natuaral gas and propane. Contact your local propane supplier for assistance in gettting the correct jets.
Jan 12, 2011 | Dryers
Convert natural gas to propane
The unit when new would have come with a spare set of gas jets for the top burners which should be included in the manual.If not then you will have to get in touch with your supplier.These jets will have numbers on relating to the table in the book.
Hope this helped.
May 10, 2010 | Garland H284-24G Kitchen Range
I have four S-25 spot patio heaters. They were converted to Propane by following instructions provided by Sunpak. My house is new construction and the propane distribution was installed, tested, and...
Hello George. If Suburban is still your provider call them and ask them to send out a technician familiar with these patio heaters. If you now have a different propane provider call with the same quiry. There should be no charge for this visit as you are a valuable customer. Suburban can certainly check the jets to be sure that they are propane jets. I believe your propane provider will solve this problem for you. Regards, Joe
Jan 14, 2010 | Sunpak S25 Heater
Coversion
all i for sure is that for propane gas you will need smaller burner jets because of the higher pressure. ive done this the other way around, converting from propane to natural gas by drilling the jets bigger with tiny drill bits
Aug 01, 2009 | Kitchen Ranges
I want to be prepared to change my Carrier Furnace from Natural Gas to Propane if I need to.. I was told that their should be a little sack with a replacement jet hanging there somewhere. There is not.. ...
not only do you need the nozzles....you will need the spring changed in the gas valve and a manometer to set the proper gas pressure output from the valve.If you change the jets only you could do alot of damage to your furnace.
Sep 23, 2008 | Carrier Heating & Cooling
Propane gas flame too high on the burners of a drop-in Whirlpool cook top. How to adjust the burner flame.
if it set up for propane or natural gas need to make sure if for propane you need to change the orifice in the cook top, it is shipped for natural gas call the store and they can order the kit
May 06, 2008 | Kitchen Ranges
Bosch Nexxt WTMC 6500 Gas Dryer Logo
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
