Question about Nikon Coolpix 4500 Digital Camera
When I turn on my camera it says the memory card is write protected
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Aug 05, 2010
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
robmcd27
  • 423 Answers
SOURCE: my DSE memory card says 'write protected'
Hi there, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Posted on Feb 27, 2009
  • 53 Answers
SOURCE: MY MEMORY CARD WHEN INSERTED SAYS:PROTECTED IMAGES
there should be a little swith on the side of the card. switch to the opposite and then try
Posted on Aug 26, 2009
Testimonial: "Thank you! You fixed my problem!"
  • 102366 Answers
SOURCE: "memory card is write protected"?? but it's not the memory card!
It's not the camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
  • 11967 Answers
SOURCE: When I turn my Kodak
Move the slide switch on the side of the card to "unlocked"
Posted on Aug 10, 2010
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
How did my memory card get protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 29, 2014 | Kodak Easyshare CD82 Digital Camera
Screen says "Memory Card Protected" and will not take pictures.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2012 | Fujifilm FinePix C10 3x Optical Zoom, 10...
After I left my memory card in printer, now when i turn camera on - memory card protected (reset switch on memory card) how do I do this?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 05, 2011 | Kodak EasyShare C613 Digital Camera
Camera says memory card is write protected. How can I delete pictures on the card and take new ones?
write protection lock is turned on,, turn it off this maybe 1. a switch located in the camera 2. on off option in the camera menu else plug the camera to memory card reader to delete or format the chip :)
Dec 15, 2010 | Nikon COOLPIX S51 Digital Camera
When I turned my camera on it said locked how do I fix this
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 31, 2010 | Samsung TL100 Digital Camera
How do i turn off the memory card protect
There's a sliding switch along one edge of the card. Move it away from the contacts.
Dec 18, 2009 | Nikon Coolpix S210 Digital Camera
How do i turn off protected card on my camera? i have a sanyo vpc-e1000
If you mean by removing the memory card protection, turn off your camera and take out the memory card. Look for a small tab in the memory card that can be adjusted up or down. Usually, to unprotect, it should be adjusted upwards or if it doesn't adjust it downwards.
Dec 04, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Memory card is protected how do i switch on memory card when i turn camera on, message reads that the memory card is protected and to reset switch on memory card. what happened?
Oct 11, 2008 | Kodak EasyShare CX7330 Digital Camera
Turning on the camera
Please look at the memory card closely. If there is a write protect switch, it will give you this error. Please ensure that the write protect switch on the memory card is not in the lock, or protected position.
See more information about SD cards here.
Let me know if this helps!
Brian
Jan 08, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
176 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
