Question about Frigidaire Dryers
Dryer gets very hot in all settings, starts getting hot as soon as knob is turned w/o hitting start. What is problem?
  • Frigidaire Master
  • 1,606 Answers
The heating element is grounded , sending 120 volts thru the element when the timer is turned on ( without starting dryer . Normally , when the timer is turned on , it sends 120 volts to the element and when the motor starts , it sends the other 120 to the element ( the element gets red on the 240 volts ) . You will have to raise the dryer top , remove the front panel , disconnect the belt and remove the drum by by lifting it up out of the bearing slot in the rear . Then the element will be visible . Probably a portion hanging down and finally touched the element housing . The complete element and housing should be replaced , so take the complete model number which is on the front panel behind the dryer door , with you so you get the correct element .
Posted on Aug 05, 2010
  • Mike Smith
    Mike Smith Aug 05, 2010
    When the dryer is running and the element cycles off due to thermostat , it still gets 120 volts and getting hot but just not red hot . You will notice the top at the console getting hotter .
  • Mike Smith
    It is also possible something slipped thru the rear drum holes , such as an ink pen cartridge , metal bra support ..etc , in which case replaceing the element may not be necessary . Just removing the object .
Have to pull the start/timer knob many times to get the dryer to turn on. Have replaced timer and door switch.
Hi Anonymous,
The timer knob is defective and will need to be replaced soon.
Good Luck,
JP
Jun 29, 2015 | Dryers
How do I dry only
When using the WD-1000 as a Dryer only, are you turning the rightmost knob Clockwise to the correct starting point?
Looking at the periphery of the knob, at the bottom, see the elongated "sausage" shape, outlined in blue? Turn the knob so it passes "Stop", and points there.
At the end of a completed Wash Cycle, that is where the pointer will be pointing. Once there, the machine switches automatically to Dryer Mode.
As long as the middle dial is set to a timer length greater than zero, the drying begins. I recommend turning the middle dial to somewhere around 2:00 o'clock, which corresponds to about 90 minutes if I remember correctly.
(You'll notice that is in the "Orange" area, meaning Full Heat - which is always fine because it never gets too hot anyway)
So, turn right dial to point to the "white sausage" at the bottom of the dial; Turn middle dial to 90 mins, or so; (Left dial only controls "Spin" speed - just set to max); and close the door. (It should begin drying)
Feb 14, 2015 | Malber WD1000 Front Load Washer/Dryer
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
Estate Dryer: No Response After Hitting Start Switch
Good job with that.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 03, 2012 | Estate Dryers
Kenmore dryer 80 series start and working until get hot then stop and i have to wait some time and then press start again.During that time program control knob doesn't move
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2010 | Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer turns on, gets hot, but knob does not move with timer.
could be your operating thermostat on your heater or your timer if it runs on timed dry but not auto dry then it is a thermostat issue if it just does not run at all then it is a timer issue also make sure your vent is clear check by removing vent hose from back of unit and running a load if it works properly clean your vent.
Feb 23, 2009 | Hotpoint NVL333EY Electric Dryer
Drum will not turn
From your description, you may have a bad spot in the armature of the motor, or a faulty centrifugal switch on the motor.
May 24, 2008 | Dryers
Dryers Logo
51 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
