Question about Conair Weight Watchers® WW78 by Glass Body Fat Scale Black Chrome
The scale itself won't turn on. - Conair Weight Watchers® WW78 by Glass Body Fat Scale Black Chrome
Calibrate Salter model 9140 bathroom scales
Remove the battery and count to 10 and then replace it.
i found this
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
and also this
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery until you first complete the steps listed above.
Not sure if this is the correct manual, but may be close. Page 3 and 4.
Salter Housewares Body Fat Computer Instruction Manual Page 3
Nov 27, 2017 | Salter Health & Beauty
Fix an EE error
That means that the scale cannot calibrate itself. When it turns on it checks the sensors to see if they are in range. It cannot find the sensors or they are out of range.
Nov 03, 2015 | Homedics SC380 Scale
Ohaus scale won't turn on
Hi Bud, The unit has a built-in adapter which could be the problem but best to call Ohaus directly at 800-526-0659.
ED
Dec 06, 2012 | Ohaus Ranger Heavy Duty Compact Bench...
I ran a cycle of vinegar through special edition brewer and it continues to say de-scale after doing scaling. it won't pour water sometimes and has to be turned on and off to get it to pour water. ...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 14, 2011 | Keurig Platinum B70 Coffee Maker
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Conair Weight Watchers® WW78 by  Glass Body Fat Scale Black  Chrome Logo
793 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
