Question about Linksys WRT160N Wireless Router
Where do I find the network security key? - Linksys WRT160N Wireless Router
  • 550 Answers
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
Click Here for step by step instructions
Posted on Aug 07, 2010
    President:
  • 2,571 Answers
Log in to your router, default log in is usually admin and admin.
go to wireless and security, set or check your WPA2 security password here
Posted on Aug 05, 2010
Where is the network security key
The network security key is set by the user when the home network is setup. It prevents people from stealing your wireless signal. If you have forgot it, or didn't set it up but it still is asking for one, you can unplug and hit the reset button on your router and delete the home network you have on your main computer. From there, just run the network setup wizard from the main pc and set your network security key to something you can remember as well as write it down. Then you should be set to add any other pc to your home network as long as when you try to connect, you put the correct key in.
Sep 28, 2012 | Belkin (F5D7231-4) Wireless Router
Tip
Setting up your Wireless Printer: How to check your Network Settings
To check your network settings from your computer
  • for Vista click on start then Connect To, then right click on your network and click Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows 7 Click on the Network/Wireless icon on the task tray click on Properties, write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
  • for Windows XP click Start, then Connect To then Network Connections, right click on Wireless Network Connections click on Properties then write down the Security Type, Encryption Type & Network Security Key. ( check the box if all you see is dots)
on Mar 28, 2011 | Office Equipment & Supplies
How do I find the WPA to set up wireless connection on my new laptop
    • 1 Right-click on your network bar in the bottom right corner and click "Open Network and Sharing Center." You can also click "Start" and type "Network and Sharing Center" in the search box. Click on the Network Sharing center link in the search results list.
    • 2 Click "Manage wireless networks" on the left-hand pane.
    • 3 Highlight the network you wish to retrieve the WPA or WPA2 security key from; right-click it and select "Properties."
    • 4 Click the "Security" tab to see the security settings. The type of security will be listed along with the encryption type and security key. The security key will be hidden.
    • 5 Check the box labeled "Show Characters." The network security key will now be visible.
Apr 12, 2012 | Zonet ZSR4154WE Router
Trying to secure wireless network
Welcome to Fixya. If you want to secure the network you all you need to do is to access the router settings page and put a security either WEP, WPA or WPA2 and a Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless, Select WEP, WPA or WPA2 and personalize a Security Key or Network Key (Passphrase). Security Key serves as a password on the network.
If you have questions please let me know. Thanks for using Fixya.
Mar 25, 2011 | Belkin (F5D7633UK4A) Wireless Router
How do I find my security key #?
Welcome to Fixya. If you need the Security key or Network Key you need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Security Key. The Network Key serves as a password or security code on your network to make it secure
Mar 11, 2011 | Linksys WRT160N Wireless Router
How do I find my WEP Key?
You can give a try using the HP Network diagnostic tool and it should give you your network details
Click on the link below and follow the steps
HP Network Diagnostic Tool
Regards,
Ron
Feb 25, 2011 | Linksys Wireless-G Broadband Router
What is a wireless network connection network key also called a wep or wpa key. Or where can i find it?
Both are security protocol which enable the owner of an wireless network to limit the acces to that network and to protect the data that runs through that network.
WEP stands for WIRED EQUIVALENT PRIVACY and it' a security algorithm designed for wireless networks with the intention to provide a level of confidentiality close to the wired networks
WPA stands for Wi-Fi Protected Access and it's a security protocol designed to secure wireless networks
If your wireless device discovered a network that require such keys,that means that the owner of
that network secured his network,only people having acces are those who know the key.
If you have a Wi-Fi router and you forgot the key ,you have to acces the configuration page of the router ,go to wireless security page and reconfigure it, by changing the key.(get the manual of the router and follow the steps)
Feb 19, 2011 | Computers & Internet
What does it mean by network security key
The name 'network security key' is itself self-explanatory. Every network has a security key and you will need this key to be a part of that network. Just as is the case of any other term that comes from the field of network engineering, there are a lot more details attached to this term, too. So, let us try to understand all the aspects related to network security key
An explanation as to why we need a wireless network security key is not even required. Still, if any one is skeptical about adding any complexity to their available wireless network, just think about it. Your wireless network range can be detected by any other computer with a wireless setup and that comes within the range of the network. So, without you knowing, it's very easy for any user to get connected to your wireless network and gain access to all the data that you intend to share only with those computers with which you have setup your wireless network. So, what is a wireless network security key and how is it useful in such situations?
Well, a network security key or passphrase is something like a password, which any user who wants to connect to your computer will require. But, I think that before we go into the details of figuring out, how to get network security key for wireless computer, we should take a look at the different methods of securing your wireless network
Oct 03, 2010 | Computers & Internet
How to secure your network
You can secure your network by putting a Network Key in it. Network key is a password on the wireless network for you to be able to connect. Just access your router thru your browser then go to wireless settings, you'll fine there the network key. You can personalize the Network Name, Network Key and Network Authentication or Security.
Aug 01, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can not connect my Lap top to Wireless connection.
Network security key is almost similar to a password.The network administrator set the key.In case you have a personal router logon to 192.168.1.1 on your browser addressbar.Got to Wireless security on the router configuration page.the network key can be edited from there.
May 16, 2010 | Westell Wirespeed VersaLink...
Linksys WRT160N Wireless Router  Logo
437 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
