Question about Kenmore 60172 Electric Commercial Dryer
Model# 110.72602101 Kenmore Dryer I had ordered the belt replacement but the instructions show an Idler Pully but I don't seem to have the wheel that goes on it. Not sure how this belt is to be installed. Can you help me?
  • Kenmore Master
  • 2,699 Answers
You must have the older style pulley that's all metal with no wheel.rap the belt around the drum,on the side where the pulley is pinch the belt together stick it under the half moon part of your metal pulley and stick the looped end around the motor shaft,if i were you i'd call the place where you bought the belt from give them the model number and order a belt kit,you get the belt,the rollers and the pulley with the wheel not that metal **** piece and replace it,you get all those parts for short money,cheaper than buying them seperate or use it for now until it starts getting noisy.let me know how you make out and if you need anymore help let me know
Posted on Aug 05, 2010
3 Suggested Answers
  • 278 Answers
SOURCE: cant install my belt back on my idler pully on my
Howdy: Check for the bolts that hold the pully on. Loosen the bolts and the pully should stat to open. You may have to put on the belt then install the pully. Look close at it. Good luck - Doug
Posted on Dec 09, 2009
  • 77 Answers
SOURCE: need to replace drum belt not seeing an idler
i can't say that i have ever seen a dryer with one
Posted on Aug 13, 2010
I have a Kenmore Dryer whick squeals, especially upon startup. I have the parts kit 4392065 from a neighbor who had the same problem with his dryer, but I have no instructions or schematics. I am looking...
remove 2 screws at filter. use a screw driver and pop hood from front. remove 2 screws at top front on inside and remove front of dryer. roller wheels are easy to repalce. place belt around drum. idler pully fits in slot just beloew moter pully. check its position while you have drum out, that way you know where it goes or you can actually put it in tis place bfore installing drum. helpful hint, after putting drum in place, reach your hand back to the right side roller wheel and pull it slightly forward. last put the belt on the idler pulley. go over the top of the pulley from right to left and then under and around motor pulley. it will only go on one way , the other will be obviously wrong. good luck.
Jan 29, 2010 | Kenmore Dryers
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Show me how the belt should be run
Stick the idler in the floorboard, even with the motor pulley and have the idler wheel facing to the left of that motor pulley. Insert the non twisted belt into the idler between the cheapass metal idler pulley mount(have yer woman hold that drum up, make her proud to assist) and now yank back on the idler good nuff to get that belt looped over that motor pully. Then let that idler go so the tenshun on dat boy cause dat belt to stay all propah on dat pulley. Replace that front panel. 05cc3f4.jpg
Belt config
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 26, 2009 | Kenmore 62802 Electric Dryer
My belt fell off and im trying to put it back on however all I see is something with a wheel and I can't figure out how to secure the belt.... any ideas?
thats the idler wheel..put booth sides of belt coming of drum between that idler bracket the on the motor pully..onthejob
Nov 26, 2008 | Kenmore 62872 Electric Dryer
Squeeking
most common problem is a bad idler pulley and/or roller assy, you can order a repair kit for your dryer probly under $40, includes new rollers, belt and idler pully part number 4392065
Mar 23, 2008 | Kenmore 62822 Electric Dryer
Replaced idle pulley but drum wont spin when clothes are in it
Ok, when you removed the front cover to gain access to the idler pully, did you make sure that the drum didnt slip off one of the two roller wheels in the bottom rear of the dryer. If you get one of those roller wheels jammed and not in the track right, they will jam up. Look down at the bottom, grab the rollers, and pull them forward to be sure they are in the groove of the drum. Also, are you sure you relooped the belt correctly back around the idler pully? The best way to loop the belt is to place the idler pully in the correct position, then drop the belt down in front of it, loop the belt under the idler pully, push it back to tension everything, then take the loop and go over the motor pully (should be pretty tight). See if one of those solutions will help. Also be sure that you are properly getting the drum in the right position over the front seal (front should go on pretty easily, if not, reach your hand in the door, and lift up on the drum to center). Thanks and good luck!!!!
Jan 25, 2008 | Dryers
Kenmore 80 series dryer.
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Kenmore 60172 Electric Commercial Dryer Logo
227 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
