The aggitator (sp?) isn't turning...the rest seems to be working (spin & fill). How do I fix it and is it worth fixing? Model LBT6133A Whirlpool Washer
  • 101 Answers
Go under the aggitator inside the tub and pull out the aggitator it self and check out see if the teeth are strip,If the teeth are strip on the aggitator replace it. If is on the other side then it's not worth repairing. All you need to do is just pull on the aggitor from the bottom.
Posted on Apr 26, 2008
GE Top Loading washer doesn't aggitate properly.Model # WJSR4160DW
Reach into the washer and try to turn the agitator by hand and if you can turn it freely the agitator coupling (sometimes called the air bell) is stripped out. If that isn't the problem let me know. Here is the part should you find it bad.
Nov 02, 2012 | GE Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
I have a GE topload washer, I think the model # is WBSP1060T( there were three model # on the washer-VVSRV1040V & YVSR1040V were on there too) any way the water will not stop filling no matter what...
as to the filling issue this would either be the pressure switch or the hose that goes to the pressure switch to the tub has come off if you have any further questions message me back and please remember to rank this opinion it allows me to help others in similar situations Thanks Rick
p.s the starts agititating is normal when the lid closes it is engaging the lid switch
Mar 14, 2011 | GE WBSR3140D Top Load Washer
Model 110.26901690, aggitator spins freely both directions when moved by hand. Wash drum rests off center to the front of machine.
You've got a brake/transmission problem. This is a major fix, best left to a qualified repairman and probably means you're going to have to evaluate whether it's cost effective to fix vs replace.
In your cost evaluation, recognize that even after it's fixed you still have a unit with the value of a USED appliance.
Jan 01, 2010 | Kenmore Washing Machines
Kenmore washer model 110.91210100 bought in 1992 won't spin, goes thru the cycles but won't spin out? Is it a coupler? Is it worth fixing?
if its aggitating properly it is likely the transmission and i would not reccommend reapair for that
Oct 08, 2009 | Washing Machines
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
