Question about Casio DW9052-1V Wrist Watch
Casio DW9052-1V how to set the watch after battery change?
  • 2,334 Answers
YOU WILL FIND IT IN MY TIPS.
Posted on Aug 05, 2010
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
How to reset a casio g shock watch
HOW TO set your time on a G-Shock watch - YouTube
? 0:56
https://www.youtube.com/watch?v=_cwKYE1JMXM
Apr 8, 2013 - Uploaded by JseanSSent
This is a how to video on setting your G-Shock. ... Casio GSHOCK GA110GB-1A REVIEW ' How To Set Time ' LIGHT DISPLAY - Duration: 2:59.
Reset gshock - YouTube
? 1:41
https://www.youtube.com/watch?v=s6XVUqui6Nw
Jun 7, 2014 - Uploaded by aswan yusof
Tutorial how to reset gshock after changing battery. ... Reset gshock .... GA110-1B Stealth Black Casio G-Shock WatchReview - Analog DIgital ...
Dec 29, 2015 | Casio Watches
Where can i get my casio wave cepter repaired
Yes, it is likely battery is weak.
Take it to a watch repair shop to be replaced, and do not forget to instruct them to reset the watch after battery exchange. Otherwise it will not work properly.
Regards.
TicTacArea.com Casio Official
Casio Watches
Aug 19, 2014 | Watches
Need instructions how to set casio pathfinder model1470 changed battery now needs to be reset cant find instructions old watch but worked well
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 21, 2011 | Casio Watches
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the watch battery for Casio DW-6900?
    mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
    Aug 27, 2010 | Watches
    SET AFTER BATTERY CHANGE
    You need to follow the instruction manual after changing the battery.
    Select "support" and the "manuals", watches;
    Accept terms
    Click on "search" and the download your instructions.
    Feb 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Setting a Casio Wave Captor watch after battery change
    If the watch is running try to sync the watch 1st, meaning set the minute and hour hands pointing to 12:00 o'clock. before you go to set the time.
    May 22, 2009 | Casio WVQ600DCA Wave Ceptor Watch
    Casio g-shock mtg-900 gets ERR when trying to set atomic time
    Did you go to Casio and download the manual? I just did after my battery change and I hoping it updates tonight at 2,3, or 5am with my watch in the window.
    Oct 29, 2008 | Casio Atomic-Solar MTG900 Watch
    Battery removal?????
    How do I set the watch hands, I can set the digital part, but I can not seem to change the "Hand" Settings.
    Jan 26, 2008 | Casio AW80-7AV Wrist Watch
    Casio DW9052-1V Wrist Watch Logo
    214 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
